Good Resaonable Clutch for Street Everyday used street racing
New User
NO stage 3 clutch i want some that has a STOCK feeling no so stiff.
Re: Good Resaonable Clutch for Street Everyday used street racing (Mista Bone)
hey bone do you run a stock clutch with your 85 shot.
did it hold up pretty good with the slicks too?
[Modified by dirtySOHC's, 11:26 AM 6/20/2002]
Re: Good Resaonable Clutch for Street Everyday used street racing (tooqwik1)
Re: Good Resaonable Clutch for Street Everyday used street racing (SleeperEG6)
Type-R Disc. ClutchNet PP.
[Modified by MugenEF7, 10:03 AM 6/20/2002]
Former Moderator
Re: Good Resaonable Clutch for Street Everyday used street racing (MugenEF7)
Exedy Clutches suck *****. If you want a stock feeling clutch, then just buy a stock clutch.
I have a few friends who bought the Exedy **** and they feel exactly like the stock clutch, and they grip just like the stock ITR clutch too.
If you're spending money on a clutch and you want a better than factory clutch, then I would suggest either ACT Heavy Duty P.P with the hybrid-lined street disc or a ClutchNet 25% over stock P.P and sprung hub street disc in either organic or Fiber-Tuff lining.
Clutch Masters sucks as well.
Compare a ClutchNet disc with its fully-encased springs to the ultra-shitty CM discs which are notorious for springs popping out.
I've ran ACT and ClutchNet and I could not be happier with either. The ACT I have in my B16A2-powered Si hatch is 2 years old and still barks 3rd gear.
The ClutchNet Clutch I have is more aggressive than what you're looking for, but it withstands 8000-8500rpm drag launches on slicks with no problems at all. I had over 15 passes at those launches and the clutch still grips like a motherf'er.
I have the ClutchNet Double Diaphram P.P with 6-puck, sprung hub disc. While it is not kind to the flywheel, it does grip like hell. It's the disc that hurts the flywheel though, so you could get the Fiber Tuff disc and still have a crazy gripping clutch that doesn't kill your flywheel.
D Tranny Guru
Re: Good Resaonable Clutch for Street Everyday used street racing (dirtySOHC's)
75 shot and slicks, only slipped on 3-4 power shift WHILE spraying!
When I went to 85 shot I had my Kaaz LSD, 12.2 lb shaved flywheel, and a left over Centerforce DF from a CRX swap.
Re: Good Resaonable Clutch for Street Everyday used street racing (axion7606)
Stock type Clutch works great for me. Unless your streetracing or dragracing all the time it will be fine. I have had mine for a year and half with lots of hard street driving and Autox.
Former Moderator
im happy with my clutchmasters stage 3
...For now. Wiat until your spring pops out of the disc and you cnnot get the car into any gear because the spring is in a bind and tearing **** up.
I've seen some CM discs with a ton of friction surface left but a spring(s) popped out and it wasn't worth ****.
CM is a name that is recognizable, so of course people will buy that ****.
Sorry, not ripping on you personally, but I've seen too many CM ****-clutches to ever recommend them.
Re: Good Resaonable Clutch for Street Everyday used street racing (B18C5-EH2)
Awhile back somesone suggested using the cm disk with the act pp or something like that. I have had my act hdss for 35k mi and it is not grabbing like it used to and I think I may buy one in the next year or so. Is this a viable suggestion?
Re: Good Resaonable Clutch for Street Everyday used street racing (SoloSol)
i had an exedy organic in my 00 si and also in my sohc vtec both held up very well to drag racing and it doesnt feel too bad stiff but not act stiff before that i had a stage 3 and it was killer in traffic in my gsr swap i have a clutch net i am interested to see the results from b18's words i got my hands on the one of the best cant wait to swap the bitch in the car so i can see for my self.
BTW my friend had an exedy and raced on slicks 3rd pass popped a spring so that goes to tell you i believe that clutch is more road race oriented but thats just me
hopw this helps
lata
chris
hopw this helps
lata
chris
Former Moderator
To run a shitty-*** CM disc with an ACT P.P would not make much sense to me. The CM discs are proned to springs popping out.
What ever floats your boats though guys! Don't take it from me, just go out and buy that CM and see how you like it!
Future Texas Boy
I`ve used two hyperclutches. Liked them both.
Crotchmasters is garbage.
I just purchased an ACT for my hatch.
Ryan
Ryan
i love my ACT Street strip with HD pressure plate, its a tid bit heavier than stock but still easy to engage and holds great
Re: Good Resaonable Clutch for Street Everyday used street racing (B16aVtecCivic)
Under what conditions did you have problems with your clutch? Problems can occur from any number of reasons..."Results may vary" is the term that comes to mind when speaking of clutches (and brakepads for that matter).
Former Moderator
Re: Good Resaonable Clutch for Street Everyday used street racing (EG6-SiR)
Exedy Organic with Exedy pressure plate all the way...
Good street feel with reasonably snappy response...
