going all motor.........need info
well i have finally saved up enough money to buy some stuff for my motor. i want to go all motor so ill probably be getting cams. but theres a problem, i dont know anything about cams and that stuff. if i buy cams, most likely a toda c or jun type 3 cams, what else do i have to buy?? approximately how much would i have to spend in all? what times will i be gettin with those cams?? thanx for all your info.
Re: going all motor.........need info (00fbp)
Toda C's, cam gears to tune them down...you'll need new valvesprings at the least...and a fuel upgrade...I am a turbo guy, but that should get you in the right direction
Re: going all motor.........need info (DragIIcivic)
Ever been over to clubsi? i'd start in the NA forum over there. Toda C's/JUN 3's are wild cams...you're going to need a valvetrain upgrade like drag said. I'd check it out though....to make sure things go ok the first time around.
Re: going all motor.........need info (hybridxcivic)
And the single most important part of All Motor - TUNING!!! I may make 197 whp, but my torque curve looks like the Millenium Force at Cedar Point... I am getting tuned this weekend and hopefully we'll be able to smooth it out substantially. The point is, get something that works with your setup. For Toda's, the Godspeed ECU works very well, and a VAFC can be used to dial it in precisely since not every engine operates the same exact way. For JUN, dont get that fuggin JUN ECU, get a Hondata and you'll be set once its tuned. That's the route I've gone and even with just a GS-R map with a little fuel added in (i need a lot more added in, trust me... I pulled 36 MPG on the way up to Canada, way too high) nets me 197 whp/130 torque on a B18C5 block/Portflow'd B16 head/JUN cams & valvetrain. HTH, and NA Tuning on clubsi.com has a lot of info, but you'll want to search for it as its been covered a thousand times... EV.
Re: going all motor.........need info (ElectronVTEC)
GUDE i think it is http://www.gude.com check it out!
How fast do you wanna go? And how much do you wanna spend? It might be cheaper to go Turbo or SC. The SI chasis is pretty heavy so making that B16 "fast" is gunna be tough. How fast do you wanna go?
Re: going all motor.........need info (CRX_VTEC)
JUN III are crazy! I heard that there were some JUN type R's at buttonwillow that kicked the **** out of the Toda type R's. you'd need to build the head a bit, valves, springs, retainers, cams, cam gears, maybe port polish. and ecm. It's the way to go but watch for clearance problems. I'm getting the cam this winter I can hardly wait....
Re: going all motor.........need info (advanracing62)
i want to run probably high 12 or low to mid 13's is that possible with about 4 grand in budget?? what does upgrading to a new ecu do to the performance of the car?? how come you just cant use the stock ecu?? thanx for all your info
wildoutwhitegsr
04-23-2008 06:30 AM
Atlas
05-21-2004 09:16 PM
