getting off the front disc
trying to get my front rotor off but that two X screws are so hard to turn.Anyone know an easy way to get those screws off the front rotor??(with out killing the screws thanks
Re: getting off the front disc (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">
$25 at sears.
http://www.sears.com/sr/javasr...41000</TD></TR></TABLE>
$25 at sears.
Mr. Badwrench
Re: getting off the front disc (vtec y0)
if you didnt know what it was called it is an impact driver. you turn it in the direction you want the screw to go, then you hit it with a hammer.
86%
when I was changing my front disks I noticed the two screws were pretty fouled up. One looked like someone nearly stripped the head, then sautered some metal into it filling it up so you can't get a screwdriver to bight the screw... Anyone know what could have caused that?
Re: (B18Cej1)
If the screw heads are really bad, you can use a drill bit to drill the top of the screw off. Take the rotor off, then use channel locks or vise grips to grab ahold of the screw body to remove.
