Getting horrible gas mileage!!!!
I got a B16a2 block with ITR head. and a chipped P28. and im getting about 150-170 miles on a tank of 93. and a guy i know has a swap also and he is getting 200+ MPG.
Complete tuneup has been done. plugs wires rotor
Air Filter Oil change and filter
Re: Getting horrible gas mileage!!!! (blackcap)
Yea, if you are constantly at 5k and up you are going to get bad gas mileage. The key to good gas mileage is keeping your revs low and throttle control.
Re: (Atheist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Atheist »</TD></TR><TR><TD CLASS="quote">chipped ecu's tend to have pretty shitty mileage</TD></TR></TABLE>
yep wha he said
yep wha he said
Timing is fine. i have the intake cam advanced 5 degree's. I get on it about once or twice a day any other time i shift at 3800. mostly getting to work thats about it. and its not alot of stop and go mostly country roads with no stop signs
Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">Throttle control. Don't rev above 3,000. Don't get on it once or twice a day, no need to. Drive normal, don't drive like a moron. Place on neutral when you are going to stop from far back to you can idle all the way to the light/stop sign and not rev when you downshift. Etc...</TD></TR></TABLE>
sorry but i was under the impression that this was bad for the syncros/ tranny
Re: (Civiclx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civiclx »</TD></TR><TR><TD CLASS="quote">
sorry but i was under the impression that this was bad for the syncros/ tranny</TD></TR></TABLE> which part of what he said ???? also has this always been a problem since the swap?? what swap is your friend running>?? if he is running say a b18 or b16 he only has 240cc injectors... i beleive the type r has 310cc or 340 .. something like that so your motor is proly gettigng more gas ... also did you change your fuel pump with the swap?
Re: Getting horrible gas mileage!!!! (JDMlifestyle)
just dont rev above 3000rpm. i dont have a b16 or b18, but i have a d16z6. i used to rev up to 35-4500 daily and get like 200-220 miles. i just recently started revving to around 2800 and i get around 250-270 miles.
Re: Getting horrible gas mileage!!!! (jL iLLuZiOnz 9)
Jeez, you guys get some el crapo gas mileage. I can get over 300 to a tank before my Walbro pump starts giving me crap. This is in a boosted 97 hatch with the honda 240cc injectors, E-Manage, and a Walbro 190lhr fuel pump.
Re: Getting horrible gas mileage!!!! (Ricey McRicerton)
well i usually fill up my tank when i get to 270, but im still above the line enough to get to 300. i'd just rather know i have gas than barely have any gas. dont want to be on the side of the road one day with an empty tank.
Re: Getting horrible gas mileage!!!! (EM1Guru)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1Guru »</TD></TR><TR><TD CLASS="quote">its the colder weather....
i went from 300 a tank, to 210-240. </TD></TR></TABLE>
yea cold weather is probably a problem too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 »</TD></TR><TR><TD CLASS="quote">well i usually fill up my tank when i get to 270, but im still above the line enough to get to 300. i'd just rather know i have gas than barely have any gas. dont want to be on the side of the road one day with an empty tank.</TD></TR></TABLE>
Yeah, before I got my Walbro (which complains when it gets low on fuel) that sits higher in the tank, I used to drive close to 350 miles before my gas light would come on. Guess I just have a freak of nature car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 »</TD></TR><TR><TD CLASS="quote">just dont rev above 3000rpm. i dont have a b16 or b18, but i have a d16z6. i used to rev up to 35-4500 daily and get like 200-220 miles. i just recently started revving to around 2800 and i get around 250-270 miles.</TD></TR></TABLE>
same **** for me man, same engine......my last tank was 208 and i was very near empty.and mine usaully averages from 200-220...im gonna start shifting at lower rpms
Re: Getting horrible gas mileage!!!! (Civiclx)
my mileage took a dive too. i am attributing it mainly to the weather. do they add anything in the gas during the winter to make it burn cleaner? heard that before. and also, i need to change oil and do my 90k tuneup. hope it goes back to around 34mpg overall soon
Re: Getting horrible gas mileage!!!! (chads)
you guy have sucky gas milage. i get at least 240 miles per tank, most of the time 260. and i drive it hard. i shift at 4k - 5k all the time on my b16a3. shifting at 3k would suck with the torqeless b16. and there are to many hills in san francisco.
Tr0LL
06-11-2003 01:17 PM
