GAS LEAK FOUND! Couple Questions
A month or two ago i posted a thread on here asking about a strong gas smell...and i hadnt found anything untill i stopped looking... while i was getting an oil change at a local shop i was under the gas tank and was checking for anything out of the ordinary...smelled the gas and noticed a small wet spot on the tank and sure enough it was leaking from the tank...that said...should i just buy a new tank or try n have it fixed? Is it a serious thing and should i take precautions on the tank igniting? or am i being rediculous? With my luck i dont wanna blow anything off thinking its not a problem when it is! Id like to keep my car running but not a running firecracker! thanks and please dont make fun of me lol...please?
there is not enough air in your tank to ignite the gas.
so you can drive it but get it fixed asap.
people have died from their tank exploding while accidently doing something. Or not being too careful. drain the gas, switch the tanks, and be extra freaking careful. No smokers....
unless you drive arond with a full tnk all the time you have air in your tank.and if its leaking that means gas is coming out of the tank. How ever you look at it its not a safe thing to have happening. Call around there are shops that rpair tanks but it is prob. going to be less to just replace it
