Fuel Pump Wiring Yel/Grn Grounded?
is it suppose to be grounded when plugged in to the fuel pump? test continuty on both situation(unplugged from FP and plugged) Test result was when its plugged in its grounded, if not plugged, its has no continuity, definitely not the wiring if something is wrong.
Re: Fuel Pump Wiring Yel/Grn Grounded?
if you give me the year make/model and engine size i can pull up a wiring diagram at work and scan it for you if you would like and it will tell you that wires are groun power and sending unit
gofast300@gmail.com
01-30-2009 06:06 PM
Laurence
09-05-2004 05:22 PM
