doing a clutch change
Old 05-29-2010, 05:52 PM
BigAnteg's Avatar
Default doing a clutch change
i need to no if i can use this clutch alignment tool on a b-series clutchhttp://www.sears.com:80/shc/s/p_10153_12605_SP100A1798S225731513P?keyword=clutch +alignment+tool&prdNo=8&blockNo=8&blockType=G8 its the one from sears
Old 05-29-2010, 08:18 PM
Corksil's Avatar
Default Re: doing a clutch change
I didn't even look at the link.... but every clutch i've changed on a honda comes with a plastic alignment tool. It's a plastic shaft with the correct amount of splines on it, and you slide it through the clutch into the motor to help line things up.
kk i checked the link, dunno what that tool is but it looks like the plastic throwaway version I've always gotten in the box with new clutches.
Old 05-29-2010, 08:22 PM
hard_boiled_EG's Avatar
^x2, unless your buying the clutch used, it should come with a clutch alignment tool..
Old 05-30-2010, 02:52 PM
h46it's Avatar
You can do with out the clutch alignment tool, but its a bit easier with it. I just did mine with a transmission bolt and eye-balling the placement!
Old 05-30-2010, 03:03 PM
russlan44's Avatar
use 10mm long socket to align it if u dont have the tool, and look around if its even
Old 05-30-2010, 03:22 PM
Master Detailer
98civdx's Avatar
Dont need one, but i like to have them, they are cheep why not just go to autozone or something and get one.
Old 05-30-2010, 03:25 PM
Jdmglenn's Avatar
i use a ratchet extension with electrical tape haha works everytime
Old 05-31-2010, 09:09 AM
BigAnteg's Avatar
i think i just might go to autozone and get a rental one its a used clutch i dont have the plastic alignment one its a used clutch off my other gsr motor
Old 05-31-2010, 09:13 AM
8VEYBEYB's Avatar
wish you were local I would just give you one of the 10 I have.
Old 06-01-2010, 01:28 PM
BigAnteg's Avatar
i no would anyone know how many plines are for the gsr transmisson cause o'reilly's auto parts sells the clutch alignment tool buy it self
Old 06-01-2010, 05:33 PM
95EG2's Avatar
autozone has a rent a tool servive u can get one from there or any other part store that has loan a tool... pepboys, advance
Old 06-01-2010, 09:07 PM
eKsPool99's Avatar
use the alignment tool, makes things much easier, i think pepboys has them
Old 06-04-2010, 01:22 PM
BigAnteg's Avatar
yea went ahead and bought a new clutch instead of using a used one i had so wouldnt have to do it agian but thanks for everybody help
tacchan
26
03-17-2010 11:25 AM
jiggacivic
11-23-2009 08:54 AM
wkrpfm
Acura TL, RL & ZDX
12-03-2004 09:35 AM
fastlude69
07-14-2004 07:12 PM
lildrgn2.0
06-16-2004 05:29 PM
Quick Reply: doing a clutch change
