fuel pump not priming
My fuel pump isn't priming, although it was priming about a week ago.
I just swapped a b20 into a 99 civic from a 96 civic.
The only changes i made from the last time it primed until now were remove my msd digital6, bleed my clutch, remove, test and re-install starter.
I checked all fuses and none were blown. The car cranks like a champion, but since fuel pump isn't priming it won't turn over.
Dumb question: it had never occurred to me before, but would a fuse pump not prime if theres NO gas in the tank? (doesn't apply to my situation, I have a little gas in there)
I searched and didn't really find anything relevant. TIA
Re: fuel pump not priming (juzthewy)
THe pump will prime with nothing in the tank, have you checked your main relay?
*edit*, there a way to see if its the main relay, do you have a haynes manual? You take the realy out and jump 2 pins in the harness it connects too.
Re: fuel pump not priming (z6hatchboy)
alright ill give that a look.
if thats the case, are the main relays for a 96 DX and a 99 CX the same?
the relay is located behind the glove compartment its a gray box it should have 7 wires running to it you also have to take the panel off cause there is a 10 mm bolt holding it to the dash
oldschoolfever
07-01-2017 04:14 AM
Jaynik
10-22-2010 04:55 PM
