fuel gauge dropping while normal driving?
my fuel gauge is droppig while im driving normal.
it drops about a quarter then comes back up when i come to a stop, but not to its normal position.
does anyone know whats the cause of this?
bad o2 sensor?
help me out.
thanks.
bad o2 sensor?
help me out.
thanks.
Re: fuel gauge dropping while normal driving? (esoterEK..)
When i take sharp turns my fuel gauge will move because the fuel is moving away, or towards the sensor. The sensor is by the fuel pump.
Re: fuel gauge dropping while normal driving? (monicle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">When i take sharp turns my fuel gauge will move because the fuel is moving away, or towards the sensor. The sensor is by the fuel pump. </TD></TR></TABLE>
when ever i make a sharp turn or go up hill my gas gauge will drop. like luserkid said just movin away from the sensor
cool guy name
Re: fuel gauge dropping while normal driving? (Luserkid)
It doesnt even have to be a sharp turn for me, its constantly fluctuating
Re: fuel gauge dropping while normal driving? (walker111)
i know what you guys are talking about but my situation is different.
the needle moves everytime i step on the pedal and this is on normal straighaway roads and i know that im slowy losing gas.
also my exhaust is leaking from the cat. could that be the problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esoterEK.. »</TD></TR><TR><TD CLASS="quote">ttt
also. how can you tell if the o2 is bad or not??</TD></TR></TABLE>
CEL
CEL
Electrician
Re: fuel gauge dropping while normal driving? (project98civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project98civic »</TD></TR><TR><TD CLASS="quote">
CEL</TD></TR></TABLE>
Not necessarily. My O2 sensor has been shot since 5 months ago yet there is no CEL. Timing is to spec, all new fuel filter, plugs, wires, etc...etc...etc...from Honda yet my gas mileage on a bone stock D15B7 is at 200-250 per tank. If your gas mileage drops all of a sudden and is totally in the crapper, it's most likely your O2 snesor if nothing else was tampered with or touched (timing).
lol. if i down shift and accerlate hard on the freeway, my fuel gauge dips like 1/4 tank, then goes back to the previous position when i'm cruising. i thought civic fuel gauges were just ghetto like that.
leaky tank could cause pressure lose which might affect the sensor. I actually don't know if they use a sensor or a float in honda's but either way you have much more serious problems than you gauge moving, you should get the exhaust leak fixed before you get a fire.
