first oil change...00 B18C-R...which oil?
Old 04-24-2004, 01:08 PM
HUBB's Avatar
Default first oil change...00 B18C-R...which oil?
im changing the oil in my 00 B18C..jdm ITR...and ran the first couple thousand miles on regular CASTROL GTX 5w-30....what oil and weight do u guys reccomend i run in for my next 5 quarts...synthetic, regular, 5w, 10w, MOBIL 1, ROYAL PURPLE..etc....PS: i drive my car hard
Old 04-24-2004, 01:19 PM
hatchbackhonda's Avatar
Default Re: first oil change...00 B18C-R...which oil? (HUBB)
so far the best oil i have ever used so far was amsoil but it is expensive but its well worth it i am currently running it my b18c-r it is a synthetic BEST OIL BY FAR IN MY OPINION.
Old 04-24-2004, 01:22 PM
HUBB's Avatar
Default Re: first oil change...00 B18C-R...which oil? (hatchbackhonda)
hmmmm...how much is 'expensive?'
Old 04-24-2004, 01:25 PM
SOHC_MShue's Avatar
the only oil I use is mobil 1 5-w30 or 10-w30 synthetic oil.
Old 04-24-2004, 01:29 PM
skip.two's Avatar
Default Re: first oil change...00 B18C-R...which oil? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">the only oil I use is mobil 1 5-w30 or 10-w30 synthetic oil.</TD></TR></TABLE>
Old 04-24-2004, 01:32 PM
poop32145432's Avatar
Stay with 5w-30 brand wise, just keep with the well known brands such as, Mobil 1, Royal Purple, Motul, Amsoil, Redline, and the like. As for a pricing goes I would go with Mobil 1. They are all pretty much the same. As long as you change your oil frequently you're good to go.
Old 04-24-2004, 01:33 PM
Darth ModerVader
Padawan's Avatar
How many total miles are on the engine so far? I personally prefer conventional oil, but even if you intend to run synthetic, it might be a good idea to run conventional a while longer, depending on the mileage.
Old 04-24-2004, 01:35 PM
Global Moderator
Jimmy's Avatar
How about helping us cut down on some of the repeated topics....and search because this has been covered at least 10 times...
search
Old 04-24-2004, 01:38 PM
diearzte2
Guest
Posts: n/a
No kidding.... There have to be hundreds of threads covering the topic of the best brands of fluids.
HUBB's Avatar
Default Re: first oil change...00 B18C-R...which oil? (Padawan)
i have only thrown down about 2k miles since i poured in the castrol when i did the swap.....ive been rapin my motor hard so im thinkin to give it its first real oil change tomarrow...just want to give the best all around nutrients...
Old 04-24-2004, 01:39 PM
HUBB's Avatar
true, true.....my bad for the repeated topic discussion...hammer time... ...just needed some quick advice
Old 04-24-2004, 01:49 PM
Darth ModerVader
Padawan's Avatar
So the engine only has 2000 total miles on it (i.e., it's brand-new)? I'd stick with a quality 5W-30 conventional for at least another couple of oil changes.
Old 04-24-2004, 01:53 PM
HUBB's Avatar
no it has around 25k on it
FoxRiderH22A
07-03-2009 06:30 AM
ahron
09-09-2007 06:59 PM
ironballz
05-13-2004 02:38 PM
blkbeast
05-28-2003 10:48 PM
TypeR01-424
08-17-2001 07:51 AM
Quick Reply: first oil change...00 B18C-R...which oil?
