Finally...THE motor arrives, pics of 2.1L B16
Here are the pics of my engine that I just got back from Golden Eagle. Let me know what you think!
I dont have any idea what I did wrong?
Re: Finally...THE motor arrives, pics of 2.1L B16 (VTECJUN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECJUN »</TD></TR><TR><TD CLASS="quote">Here are the pics of my engine that I just got back from Golden Eagle. Let me know what you think!
I dont have any idea what I did wrong?</TD></TR></TABLE>
Maybe because you didn't attach any pictures?
Re: Finally...THE motor arrives, pics of 2.1L B16 (Phastnphun)
The motor is a B16a. I used an LS crank, custom Eagle Rods, 85mm 12.5:1 Arias Pistons, .75 deck plate, Golden Eagle Godzilla sleeves. JUN 3 cams, gears, springs, retainers, flywheel. I am going to puut it in the car pretty soon. I had to have custom mounts built for the hood clearance issue. Ill have more pics later.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECJUN »</TD></TR><TR><TD CLASS="quote">The motor is a B16a. I used an LS crank, custom Eagle Rods, 85mm 12.5:1 Arias Pistons, .75 deck plate, Golden Eagle Godzilla sleeves. JUN 3 cams, gears, springs, retainers, flywheel. I am going to puut it in the car pretty soon. I had to have custom mounts built for the hood clearance issue. Ill have more pics later.
post more pictures of the hatch. it looks good
senior gold member
how were you able to reach 2.1? did you overbore also like to 84mm? how much longer are the rods? did you have to notch the block? I give you props most people would have just went with a b18 sleeved and overbored but you have something not everyone will have although not cost effective
Re: Finally...THE motor arrives, pics of 2.1L B16 (Ivan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan »</TD></TR><TR><TD CLASS="quote">how were you able to reach 2.1? did you overbore also like to 84mm? how much longer are the rods? did you have to notch the block? I give you props most people would have just went with a b18 sleeved and overbored but you have something not everyone will have although not cost effective </TD></TR></TABLE>
1.6L + Deck Plate .3L (?) + from 81mm bore to 85mm (.2L) = 2.1L
Does that seem right?
Killer setup
Killer setup
Pics look good Matt. I forgot to bring my digital camera the other day when I was over. How does the header do with the oilpan on? Talk to you later.
can I haz?
2.1 my ***
i got my B20 bored out to a 85mm and even doubt thats a 2.1 maybe 2.08. if u have a 85mm B16 mad props but u better go back to math 101 cuz it sound shady
Re: (thid92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thid92 »</TD></TR><TR><TD CLASS="quote">2.1 my ***
i got my B20 bored out to a 85mm and even doubt thats a 2.1 maybe 2.08. if u have a 85mm B16 mad props but u better go back to math 101 cuz it sound shady</TD></TR></TABLE>
Since when is a h22a1 2.2L or a b16a 1.6L...I don't think so....Honda always bumps the numbers on their engines up.....2189cc=2.2L...go figure. If you are pushing 2.08L, I count that as 2.1L all day long.....can you say 260whp with the right tuning!!!!!
Re: (SiBirdie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiBirdie »</TD></TR><TR><TD CLASS="quote">are you using stock water pump ? or and external? What timming belt you are using? damn nice </TD></TR></TABLE>Yeah what timing belt?
