failed smog test
failed smog test
my civic failed smog test and i was wondering what should i check...
92 civic si
d16z6 with greddy turbo
greddy turbo bov
everything else is stock
thx in advance
pmed hazw8st, hope he can help me
Modified by noss88 at 9:56 PM 2/9/2007
92 civic si
greddy turbo bov
thx in advance
Re: failed smog test (noss88)
any shop should know that a aftermarket turbo car will not even pass e-test... if they still went ahead and did it for u then they r just tryin to take ur money...
1 Post
Re: failed smog test (KnightX)
Now wait just a second. There are C.A.R.B. legal turbos that should pass the E-tests. The California Air Resources Board tests them to see if they do increase emissions, if they don't then they are assigned a CARB# and are very legal. Even in California.
What I would do is find one that is legal and uses the greddy turbo and try to match that set-up. As in timing and boost pressure etc...
and if that doesn't work:
most likely that the catalytic converter is not enough for the D16turbo (it is for the D16 NA)...so try to put a bigger one, for some 2,0 engine Honda has got...
if u have a turbo, then u kew when u put it in that u werent going to pass smog. that why if ur going to do **** like that, u gotta know ppl in da smog bidness.
Re: (bonestock91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bonestock91 »</TD></TR><TR><TD CLASS="quote">if u have a turbo, then u kew when u put it in that u werent going to pass smog. that why if ur going to do **** like that, u gotta know ppl in da smog bidness. </TD></TR></TABLE>
you can pass smog with the turbo. he just has to make sure everything is running right. right air/fuel mix, cat working. its a smog legal turbo. so it can pass legally.
is3oo
08-27-2004 12:36 AM
