ex harness
ex harness
i know that an si engine harness wont clip into my car because i have a 98. but i picked up a 99-00 ex harness in the hopes that it will clip into both the car and the b16a2 that i have in there. is this correct?
Re: ex harness (fhtfhatchy)
NO, the harness for the b16 will not fit the EX, because the EX used the SOHC d series.
You need to locate a junkyard Si, with a harness to make it work.
Re: ex harness (Red_EM2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_EM2 »</TD></TR><TR><TD CLASS="quote">NO, the harness for the b16 will not fit the EX, because the EX used the SOHC d series.
You need to locate a junkyard Si, with a harness to make it work.</TD></TR></TABLE>
No sorry, this is incorrect.
Your car is an '98(obd2A). Neither the '99 si nor ex(both obd2B) harness will not work in your car.
You need to either reuse your stock harness and adapt it to fit the b16a2, then add wires for vtec solendoid, vtec oil pressure switch, and knock sensor. Also you'll need to change from 3 wire IACV to 2 wire.
Or
Get an EX harness (must be '96-98) and adapt it to fit the b16a.
Thats it, since the obd2 EX harness is already wired for vtec and knock sensor.
* the reason I wrote "adapt to fit b16" is because you didnt secify what obd the b16 is. If its obd1, you'll have to change plugs for injectors, alternator, and distributor.
Or
Re: ex harness (Slopoke)
ooo that makes sense. i have a 99-00 ex harness, but that wont work i will need one from my year. but will that plug right into the si ecu that i have?
Re: (duggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duggy »</TD></TR><TR><TD CLASS="quote">Yes, it will plug in, but your gauges will not work correctly.</TD></TR></TABLE>
Along with quite a few other things.
So in other words, it wont work. lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fhtfhatchy »</TD></TR><TR><TD CLASS="quote">ooo that makes sense. i have a 99-00 ex harness, but that wont work i will need one from my year. but will that plug right into the si ecu that i have?</TD></TR></TABLE>
If your using the '00 Si ecu, then you will need a obd2A-obd2B jumper harness.
