EVAP PURGE question
EVAP PURGE question
My setup as follows, currently doing the swap.
1992 Civic DX HB
2001 OBD2 B18C swap running a JDM 95 OBD1 P72 ECU.
Question is can just remove the EVAP purge selenoid completely and cap off the line to the TB? Will this throw a CEL? I don't wanna hassle with runnin another wire to A20 on my ECU. any help would be appreciated! Thanks
1992 Civic DX HB
Re: EVAP PURGE question (Revolution2zz)
you can unplug it and cap it off, the jdm ecu does not look for the evap purge solenoid so you will not get a CEL, its only to put air into the gas tank when gas is pulled out.
