erratic tach, engine misfiring.. plz help...
The symptoms of the problem are that while driving the tach will jump all over nd the engine will hesitate and misfire. since this started I hve done the following
1. swapped ecu's with friend and same problem off the bat.
2. I replaced the entire distributor with new one. ran fine for 20 minutes then problem came back.
3. after a week the engine finally threw a code 1 (oxygen sensor) I replaced the oxygen sensor and it ran fine for about 10 minutes then same problem.
4. I got another distributor. ran fine for bout 30 minutes then same problem.
5. I replaced boshe platinum with denso iridium plugs. ran fine for like 5 minutes then same problem.
6. I replaced my msd 8.5 wires with stock wires. ran fine for about 25 minutes then same problem.
WTF.. the only thing I can think of is my throttle position sensor.
ny clues would be helpful..
and since I replaced my oxygen sensor it is not throwing any codes.
ttk3
16
04-23-2007 11:21 AM
koatic
01-17-2006 12:07 PM
