ENGINE SWAP INFO & FAQs,HOW-TO CK ENGINE LIGHTS
#26
Global Moderator
Re: What swaps are available for my Civic? (MinesBiggerThanYours)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MinesBiggerThanYours »</TD></TR><TR><TD CLASS="quote">Well i don't know wheter or not this is the right thread but, i have some questions for you swappers out there.
Car-92 honda civic si
engine possibilities...
b16a2
b16 (out of ctr)
b18(out of gsr)
b18c5
Now here are the questions...
1.When i swap the motor in, if it is a jdm motor, will i be able to use the jdm harness and ecu? or will i have to tote around on the factory d16z6 until i can get a computer upgrade? ( my love and joy before honda was Rx-7s and a jdm required a usdm harness or to extend the jdm harness)
2. Will it mate up to my current exhaust or will i have to have a custom cat pipe made?
3. What are any complications that i might run into... murphys law is always in effect when working on cars(I know i turn wrenches on Mercedes-Benz's for a living)?
4. How fast will my car?(i.e.-quarter mile times.. be a pessimist)
5. As far as upgrades go, the car will not get a turbo, as i will drive this car everyday as i do right now. What kinda gains would i get with cams and cam gears...I really dont want to pull apart the bottom end to make power?
6. I cant think of anything else.
Peace thanks and kudo's to ricerton,
Steve</TD></TR></TABLE>
You should be able to pull 13's with a b18c in a stripped hatch.
Really the only honda/acura motor that responds to bolts ons well would be K-series k20a(jdm) k20a2(usdm) not 100% sure on the engine codes.
Just an example:
You put a cold air intake on your swap lets say b18c5 you pull maybe 5-7 hp
You put a cold air intake on your k-series engine and you'll see a hell of a lot better difference.
If your wanting something that responds to bolt ons well go with k-series.
Goodluck bro
b16a2
b16 (out of ctr)
b18(out of gsr)
b18c5
Just an example:
Goodluck bro
#28
what the hell
dude get a d16z6 turbo. yea you could get a b or k or whatever yall wanna call up. you still can't beat a d16z6 turbo. and it's just 1500$. you can kill any motor na. yea yea you can turbo those suckers, yea if you wanna play 3000$ for the motor 4000$ for turbo and boost 8. haha blow your motor up. haha high compression don't work.
#29
Re: (civicmaniac)
buy a high end camshaft and a turbo kit. you can get up around 200hp with about 160tq. at a very good price. you can kill every b,h,k,d, out there. dont' forget, turbo got a much better powerband. yup, and if they turbocharge. well that's because they about 4times as much. put that in your d motor. and your be at 400hp. haha people.
#31
Re: What swaps are available for my Civic? (Ricey McRicerton)
I have a question, i have a fully redone 00' civic si and i was looking in to buying a B18C5, if i buy this block will i be able to take most of the major parts from my old engine(turbo, intake,:manafold, cams ect.) and set them on the new block with out major problems?
#32
Re: What swaps are available for my Civic? (arabtitalator(civic'si))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arabtitalator(civic’si) »</TD></TR><TR><TD CLASS="quote">I have a question, i have a fully redone 00' civic si and i was looking in to buying a B18C5, if i buy this block will i be able to take most of the major parts from my old engine(turbo, intake,:manafold, cams ect.) and set them on the new block with out major problems?</TD></TR></TABLE>
Yes, you can swap over everything AFAIK.
#33
Re: (prestoizm)
What do you think about a ZC dohc into a 97 civic coupe??? i dont know what to do i wanted to stay single cam and boost it but what are the advantages to a dohc besides HP??? im new to the dual cam world so i want some info b4 i switch over, but if i do a dual cam i dont want to spend tons of loot so is it worth it to change from a d16z6 that i put in this car and boost it or switch to a dohc ZC and boost that??????
#34
Re: (crxjester)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxjester »</TD></TR><TR><TD CLASS="quote">What do you think about a ZC dohc into a 97 civic coupe??? i dont know what to do i wanted to stay single cam and boost it but what are the advantages to a dohc besides HP??? im new to the dual cam world so i want some info b4 i switch over, but if i do a dual cam i dont want to spend tons of loot so is it worth it to change from a d16z6 that i put in this car and boost it or switch to a dohc ZC and boost that?????? </TD></TR></TABLE>
ZC motor is mainly a cheap swap for EF chassis, but there are few who put it into EG and EK's. The motor is OBD0 and some rare OBD1 of the ZC's.
I wouldn't recommend a ZC swap into an EK unless you really have your mind set on it and want the ZC swap.
I would go for a D16Z6 or Y8 if you want to go budget swap. If not a B16.
#35
Re: (poison)
thanx, i think im just gunna go d16z6, thats what i have but its still obd2, i need a new bottom end cause this one is getting tired. its only got 80k on it but i want something with less miles on it and i have a z6 head in my car right now with 28k on it so i want to find a block with about the same.... im gunna stay single cam
#37
I need complete specs for D15B3 motor, and tell me how to upgrade it, its single carburator engine in 95 civic......as far as i think u cant even put a cold air intake to the carburator.Help me ouuuuuuuuuuuuuutt....
#38
Re: What swaps are available for my Civic? (VtecbOi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecbOi »</TD></TR><TR><TD CLASS="quote">why would you wanna swap. are you given up on your motor. any motor can make you run fast. you shouldn't have to give up. your weak. </TD></TR></TABLE>
Your opinion. I didn't swap my lowly Y7 out, but that doesn't mean that it won't be gone somewhere down the road. To each his own.
#40
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
<U>K20</U>
This can be found in the new EP3, the RSX (base and Type S) as well as other cars across the world (RSX R, etc). This is the future of the swap IMHO. There is a writeup on installing one of these in one issue of Sport Compact Car magazine (June 2004 I *think*)
Pros
200 hp 158 ft/lbs torque (RSX R)
I-VTEC
Respond VERY well to bolt ons
6 speed transmission
Most have very low miles
Cons
Still super expensive
More difficult swap than a B or D
I'm very interested in getting this one done later on. HASPORT has developed many items for the EG. I like how this thread summarized pros and cons!
<U>K20</U>
Pros
I-VTEC
Cons
#41
Re: What swaps are available for my Civic? (BlackEg9sd)
B18C1 (or JDM B18C)
These come out of an Integra GSR.
Pros
Good Hp and TQ numbers (170, 121 ft/lbs respectively)
DOHC VTEC
Tons of potential
High revving
Cons
Expensive
Becoming moreso as people keep scooping them up
Slighty longer tranny than the ITR and B16
I wanna get this, but i am now worried about this: "Slighty longer tranny than the ITR and B16." How will that affect installation and performance? What does it mean to me?
Modified by Tippyman98 at 11:18 AM 7/7/2004
Pros
DOHC VTEC
Tons of potential
High revving
Cons
Expensive
#42
Yes,
i have a 93 civic hb dx..stock i`am looking for a cheap swap? Whats my best way to go? And where can i locate it i live in gulfport,mississippi ...import`s are not huge..but nice sized down here...i cant just go to a shop n say "'hook me up"" somthings going to prob have to be gotten outta state.
thanks,tommy gulfport-miss
#43
Re: What swaps are available for my Civic? (K20Civic)
Also Vortech Makes a Turbo for the B16A-Si engine that put on 117 more Hp. So a B16A is a smart swap because they are non-expensive and if you have the money the Vortech Turbo gives u big Hp increase.
#46
geat info i have the d13 single carb
civic 93 3door
forged rods
forged pistons
custom 7mm sleeves
billet cam
heavier valve springs 50 psi (i think)
ported head
injection off d15
microtech mtx 8
microtech turbo timer
550 cc injectors
msd booster 6al
msd coil
tdo4 turbo off 97 wrx
2 and a half mandrell bend exhaust
tubo smart 35mm external waste gate
turbo smart bov
turbo smart 2 stage boost controller
surge tank and pumps
very large front mount intercooler
s2000 front seats
carbon fibre bonnet
mugen and vieleside kit
rolling on bbs 16 pb previously 144 whp on 17 psi
pb 180 whp on 15 psi
no injectores on pb getting re tuned in few days
whats this about an lsd that might fit you said the d15
great info here well done people
civic 93 3door
forged rods
forged pistons
custom 7mm sleeves
billet cam
ported head
injection off d15
microtech mtx 8
550 cc injectors
msd booster 6al
msd coil
turbo smart bov
s2000 front seats
carbon fibre bonnet
#47
Re: What swaps are available for my Civic? (1.3 litre)
I have a B16A now and i puts out a solid 200hp with all my header,intake and catback, and its quick as hell compared to my old engine, im saving up for a turbo now so i can blow the doors of most ppl i know.
#49
personally the b16a is something to look at. mostly the B16a2 if you have a civic it will be the cheap , easy, and less headaches . or you could step it up to a b18c. got to have vtec either way you choose to go. good luck. oH yea make sure you do some background info. on the company you buy it from. ALOT of people or getting ripped off these days.
#50
Question for you guys. I have a '96 Civic 4dr and I was thinking about doing the B20 block with the B16 head swap. Can anyone tell me some pro's and con's about doing this swap and i would like to know what you guys think would be the best swap for my car. Thanks
