Engine Swap
Re: Engine Swap
its not its just the regular stock engine... no vtec
and im asking of some advice about what engine would be good for the swap...
and advice on how much it would be for the tranny conversion... and if i can get pointed in the right direction to do all this
Re: Engine Swap
Re: Engine Swap
That's a nice one but the hp dif won't be much.
You have a 99 civic vp right? So you have a d16y7 with 106hp
If you get the d15b it comes with 130hp, only a 24hp difference.
Re: Engine Swap
im thinkin on doin engine mods...
so was thinkin on just stickin wit the engine i have... but would it be able to hold out if i try to make it a higher performance...
Re: Engine Swap
As long as you don't go turbo without a tune it should be fine with simple mods like I/H/E
Re: Engine Swap
I wouldn't buy one from the junkyard because if it had grinds you can't return it.
I would buy a used one from a shop or a friend.
I would though get the parts from the junkyard, like manual tranny mounts, shift linkage, clutch line, clutch pedal, clutch master cylinder etc..
Re: Engine Swap
nice cuz im on a budget... and i want to start this project already.... i wanted to do exterior first but my friend told me i should start wit the engine first... so i can actually just change the transmissions
Re: Engine Swap
I would start with the looks first, then I would change engine mods and such, its gonna be a daily driver right?
No need to hurry up on the engine mods.
Re: Engine Swap
true i just really want for show... i wanna make it look nice... but i also want to put some power into it... right now i just got a new oem front bumper my old one was cracked.... i restored my old headlights cuz they had alot of residu... and put in a typ r grill... and i also got 17' bsa rims w/ lo pro tires..
