engine is shaking!!!!
today when i tried to fill my wind shell water,i noticed that my engine s shaking pretty bad,and the shift **** too, before it was quite placid,my car is a 98 ex coupe I/E/H has 60000 miles on it, i drove it for a while i didt fell anything bad,can anyone tell me something about it.thanks
Re: engine is shaking!!!! (skamal)
yeah, when i pull outta first real slow and at low rpm, the car rattles like crazy until i get going. my shifter shakes too until i rev a little bit. wut up wit that?
Re: engine is shaking!!!! (97civhatch)
its just assorted things on your car that shake/rattle when the motor is at a lower rpm and is able to vibrate things more, as you bring the revs up(even just a few hundred rpm) im guessing it fades away. mine does the same thing.
H-T Poker champion
Re: engine is shaking!!!! (deepnite)
welcome to driving stick.. It's called bogging.
edit: More gas, less clutch..
[Modified by Hatchy-Ownzjo0, 9:34 PM 3/20/2003]
Re: engine is shaking!!!! (lionhart)
If you only have 60000 miles it probably isnt the motor mount, it should last longer than that. It is probably something else, possibly your driving or the way the car drives.
H-T Poker champion
Re: engine is shaking!!!! (MLogan)
edit: it has absolutely 100% nothing to do with a motor mount.
[Modified by Hatchy-Ownzjo0, 2:49 PM 3/21/2003]
Re: engine is shaking!!!! (SuperStreetRX7)
maybe his clutch is chattering?
motor mounts, but i really doubt it
motor mounts get messed after like 250k clicks on the engine...
Re: engine is shaking!!!! (acydphryck)
Mine does the same thing and it IS the driver side lower motor mount... if you look at them there's nothing to them... replace it and get suspension tech. inserts.
I would bet money that it's torn... my car's been doing this since 100k mi. and it is the mount.. I just haven't gotten around to fixing it ( i have an insert in there and it still does it.)
but as far as living with it... you can indefinately just give a little more gas like everyone said.
