engine noise after 4000 rpms
ok my set up is a y8 block with a z6,but every time i hit 4000 rpm it makes a noise,specialy in the morning. i retarded the timming a dit because it did it at 3000rpm. did i do the timming chain wrong when i put the head. could it be that
Re: engine noise after 4000 rpms (roycivic92)
the the vtak accumilator, turn signal fluid pump or the lower dome light shorting out.
what kinda of noise is it? what does it sound like?
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roycivic92 »</TD></TR><TR><TD CLASS="quote">ok my set up is a y8 block with a z6</TD></TR></TABLE>
A Z6 what? Head? Manifold? Cam? I'm assuming the head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">but every time i hit 4000 rpm it makes a noise,specialy in the morning. i retarded the timming a dit because it did it at 3000rpm.</TD></TR></TABLE>
How descriptive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">did i do the timming chain wrong when i put the head. could it be that</TD></TR></TABLE>
So you put a timing chain on an engine that uses a timing belt . . . ?
Help us to help you. Take more time to make a descriptive post with enough information. "A noise after 4000 RPM" tells us nothing. What kind of noise? What does it sound like? Have you been able to determine a general area in the engine bay where the noise is coming from? When did this noise start? Did you notice it immediately after the head swap? It changed when you adjusted the timing? Does it happen all the time, or only at certain times (i.e. only when the engine is cold or warm)?
How descriptive
Re: engine noise after 4000 rpms (Targa250R)
ok sorry, its like a piging noise but ir goes away as the rpms go up,and i put a z6 head. as i said before,it was louder before i retarded the timming.You guys think i put the timming BELT wrong.i put top dead center on the block and on the head i alined it with the second mark on the bottom, not alined to the head.
be professional
Have you tried to pinpoint where the noise is coming from?
Often, when a metallic rattling noise occurs at only a certain RPM, it is reated to exhaust resonance. Are you sure it isn't an exhaust heat shield rattling? That would also explain why it is louder when cold and then quiets down as the car warms up . . .
i dont have a heat shield,i took it off,and when i retarded the timming it when up to 4000rpms ,it used to be at 3000rpm.
NASIOC.com
My car use to make that sound around 40-50 mph... it ended being something with my passenger wheel bearing =P.... but is it comming from one side of the car?
Location: Toronto, Ontario, Canada, North America,, Earth
Re: engine noise after 4000 rpms (Otherguy92)
My EK used to do that around 2000 RPM. Removed all of the heat shields on the exhaust.....problem fixed. There's more than one, so make sure you got all of them.
