Need help wiring City Lights and Sidemarkers on a EG..
Old 06-14-2007, 07:32 PM
Manolo's Avatar
Default Need help wiring City Lights and Sidemarkers on a EG..
I have the city lights and sidemarkers connected with the corner lens..after i turned on the lights to check them and tried the turn signals the signals do not work, the rear signals are blinking fast only but the corner lights are lit up, they just wont blink. I checked the fuses, changed the bulbs but still happening. did i connect the lights wrong?? i put the + to + and - to -, i didnt bother using the green wire..help!!
Manolo is offline
Old 06-14-2007, 07:44 PM
94eh2's Avatar
Default Re: Need help wiring City Lights and Sidemarkers on a EG.. (Manolo)
well depending on how you want your sidemarkers to function its not difficult..if you want them to be constant and blink with the corners wire up the side markers to the green and red dont wire up with the black....
94eh2 is offline
Old 06-14-2007, 07:47 PM
Manolo's Avatar
Default Re: Need help wiring City Lights and Sidemarkers on a EG.. (305accord)
so red to red and black to green??
any reason why the corners are not blinking either??
Manolo is offline
Old 06-14-2007, 09:44 PM
Manolo's Avatar
Bump..need help!! front turn signals are not working!!
Manolo is offline
Old 06-15-2007, 01:56 AM
BlueIntegraBoy's Avatar
For turn signal function... black to black, green to green
BlueIntegraBoy is offline
Old 06-15-2007, 02:48 AM
Pr0ject93hb's Avatar
Default Re: Need help wiring City Lights and Sidemarkers on a EG.. (BlueIntegraBoy)
there are three wires that come out of your harness and connect to your corner light socket. those colors are red (power) black (ground) and green (the relay that makes them blink). so if you're not getting your corners to work you didnt re-connect one of those right...which is FOR SURE THE GREEN ONE. that controls the blinking of your light. re connect .....honda put three wires there for a reason.
now for city lights run red (power) to red on your corner light, and the black (ground) to the black on your corners.
now for sidemarkers you have two choices. if you want your sidemarkers on all the time (gay imo) then you wire one wire to red and one to black, so they will be on whenever your corners are on.
of if you want them wired the RIGHT way you wire one to red and one too green (which again...green alows them to blink).
so just re-connect the green to your corner and you'll have your turn signal in the front back, and as far as it blinking fast, its just because your front turn signal isnt working.
Pr0ject93hb is offline
Old 06-15-2007, 06:56 PM
Manolo's Avatar
Default Re: Need help wiring City Lights and Sidemarkers on a EG.. (Pr0ject93hb)
ok i put on the passenger side and its working fine..i just cut up the wire, twisted them together and electrical tapped them. now my question is since i have the corners, city lights and sidemarkers on that harness, should I up my fuse since its pulling more??
Manolo is offline
Old 06-15-2007, 08:07 PM
stratedrm's Avatar
i had my city lights wired up to my corner lights and i never blew a fuse.. the little 194 bulbs dont need alot of power compared to a headlight or a radio which i believe use the same size fuses..
i suppose if you were repeatedly blowing fuses running all 3.. then go for the next size up.. but it might just be safer to keep the lower fuse in case it needs to blow for safety purposes.
stratedrm is offline
Old 06-16-2007, 02:21 AM
Default Re: Need help wiring City Lights and Sidemarkers on a EG.. (stratedrm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stratedrm &raquo;</TD></TR><TR><TD CLASS="quote">i had my city lights wired up to my corner lights and i never blew a fuse.. the little 194 bulbs dont need alot of power compared to a headlight or a radio which i believe use the same size fuses..
i suppose if you were repeatedly blowing fuses running all 3.. then go for the next size up.. but it might just be safer to keep the lower fuse in case it needs to blow for safety purposes.</TD></TR></TABLE>
you'll be fine. now enjoy your newly found jdmness
Old 08-04-2007, 06:59 PM
trakster626's Avatar
anyone know the size of the bulb for the corner lights of my eg?? the socket has 3 wires!! and its not a 1156 or 1157
trakster626 is offline
Old 12-09-2014, 02:52 PM
Gerry Cruz's Avatar
Old thread bump
need some help have thesame problem but i have the green wire connected to the city lights and side marker side marker is connected to the red wire and green and wont turn on front turn signals wont blink anymore
Gerry Cruz is offline
Old 12-09-2014, 03:01 PM
Gerry Cruz's Avatar
Icon6 Eg citylights & sidemarker helppppp....
Need some help installing city lights and side markers
have the green and black wire connected to the city lights
side marker is connected to the red wire and green into the corners lights
the front corners wont blink and side markers wont come on any help
Old 12-09-2014, 06:06 PM
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
When wiring up my side markers to stay lit as well as function as a turn signal, I ran the positive lead from the corner marker positive wire to the positive wire of the side marker. I than ran the negative wire or ground wire of the side marker to the positive wire for the turn signal.
speedjunkie_g35 is offline
Old 12-09-2014, 06:45 PM
Gerry Cruz's Avatar
http://civic-eg.com/viewtopic.php?t=8470
I used this but it won't light up and my turn signal won't blink I also have the city light connected to the green wire and the black wire
Old 12-09-2014, 09:24 PM
Fish Twig
tony_2018's Avatar
That diagram doesn't list how to wire up the city lights so you probably didn't wire them properly. Follow the guide for the sidemarkers and confirm that it is working with the option you chose, than move on to the city lights.
tony_2018 is offline
Old 12-10-2014, 07:25 AM
Gerry Cruz's Avatar
Default Re: Eg citylights & sidemarker helppppp....
Anyone ?????
Old 12-10-2014, 08:23 AM
Fish Twig
tony_2018's Avatar
Couple of posts down.
Old 12-10-2014, 12:34 PM
Gerry Cruz's Avatar
ohk will try this ill keep you posted
Old 12-10-2014, 12:58 PM
Former User's Avatar
If you have additional tech questions, please create your own thread. And be sure to include car information and any relevant mods.
Former User is offline
EF_World
14
10-12-2010 07:06 PM
D Grade
04-05-2009 09:27 PM
J3rm
08-06-2007 01:42 PM
Dien503
01-02-2006 12:50 AM
sTraNdeD
11
05-09-2004 04:00 PM
Quick Reply: Need help wiring City Lights and Sidemarkers on a EG..
