EM1 Clutch
EM1 Clutch
The clutch on my EM1 is starting to act funny, I can barely chirp first anymore. It is the stock clutch with 100,000 miles. Does it need replaced? If so, Can I just buy a new disc or do I need to buy a whole kit with everything?
Mine is doing the same thing. Slips when shifting and at the track, forget it more traction = more slip. What you need depends what you are going to be doing with it. It you just drive it and its going to stay stock you can get a new OEM clutch disc and pressure plate. Check your flywheel to see if it needs resurfaced. For a little bit more check out Exedy Stage 1 clutch and pressure plate. I have ahd really good luck with those. But just don't forget about the flywheel, if its too grooved up just get a new one.
