Electrical Help 1999 Civic!! Fuel pump switch, dome and dash lights
Hey Guys, so today I had some time to fix a couple issues with my car, but the further i looked into the car the more problems/issues i found. Here are some of the issues, wondering if anyone can help me
1.)Fuel pump switch?
I was looking under the rear seats and i saw this switch coming of one of the wire that looks like it leads into the fuel pump. I attached a photo of it, i did wire it back correctly but wondering why there would be a switch there?
2.)Dome Light/Door jambs
When i got the car i noticed the dome light wouldn't work when the doors were opened but did when the dome light switch was turned to on, i looked at the door jambs noticed both have rusted off, so i replaced one but still nothing, Do i need both to complete a circuit or what? I do have an after market radio, heard it wont work if you have an aftermarket radio
3.)Dash light Dimmer
Basically the dimmer doesn't work, but the dash lights do, any way to see if its just the dimmer thats broken or something
Re: Electrical Help 1999 Civic!! Fuel pump switch, dome and dash lights
Pry the dimmer switch out of the dash and check whether somebody shorted the red and black wires in the connector.
Does the Grn wire in the door switch connector have battery voltage to body ground? if you ground the Grn wire, does the dome light turn on?
I checked the dimmer, looks untouched
Set the ceiling light switch to the center position (turns on light when door open).
Unplug connector B from the integrated control unit in the rear of the dash fuse box. Ground ground the Lt Grn/Red wire at B8 in the connector to see whether the light turns on.
It's the ground wire for the ceiling light.
Ground the same wire in the ceiling light connector (plugged in). It's possible that the ceiling light switch is bad.
Yeah tried that. Idk if this would help, but when i first got the car there was a wire red/white that was hooked up to the fuses, not sure why but it was supposed to be connected to the DLC, so i wired it back where belongs
Tried what? Cleaning the contacts? If so, you may need to replace the ceiling light assembly. By the way, you can Ohm test the switch.
Grounding the wire that leads from the dome light, what i also did was wire that ground to the door jamb assembly directly and it worked, so we can determine that somewhere the ground cable is cut, do you know where the left and right door jamb ground wire meet?
bmxtrev
Audio / Security / Video
02-07-2015 05:54 PM
willie761
Honda Civic (2001 - 2005)
08-16-2012 04:55 PM
Silvertune
11
04-15-2012 09:20 PM
skelton5033
12-13-2010 05:28 PM
dungeonKing
08-22-2006 12:30 PM
