EK Headlight Harness?
ok 2 days ago my drivers side headlight went out, still had highbeams, still had the turn signal/parkinglamp. just didnt have the lowbeam. so i got some PIAA Hyper White bulbs... but still same side no lows. went to autozone got the cheapshit, no lows. took the passengerside light plugged it into the drivers harness, no lows.. put it back into the passenger side its workin fine. so my question to HT, fuse or harness or something else? these are stock headlights btw, if it is the harness how much of a pain in the *** is to get a new harness in there and where can i get 1 cheap. THANKS H-T
Re: EK Headlight Harness? (lswift)
I'd say it's the harness, but it wouldn't hurt to start checkin fuses if you haven't already.
But if it's the harness, I'm guessing it will be easy to repair once you find the problem.
Re: EK Headlight Harness? (smithenhiven)
[QUOTE=smithenhiven]I'd say it's the harness, but it wouldn't hurt to start checkin fuses if you haven't already. QUOTE] is there a fuse just for the drivers side low beam though? i dont have my manual infront of me to check, but that doesnt sound right to me. jus a thought.
http://www.hondaautomotivepart...RNESS
it's #7
the harness is connected to all the wires in front of the engine. find someone that's willing to just sell the harness.
it's #7
I got a new h4 harness from pep boys, it came with the h4 plug and the 3 wires attached to it, I replaced mine becuase it got burned out, just to give you a idea
Re: (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">there is a fuse for the LOW beam on the fuse panel!</TD></TR></TABLE>
cool i was at work earlier and couldnt check. ****** 90 bucks for the harness sons of bitches!. that **** has got to be a pain to rewire huh. ill check the fuse in the morning. anyone know what the fuse # is?
Re: (jay.dee.em1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jay.dee.em1 »</TD></TR><TR><TD CLASS="quote">$90?!?!?! damn son...who ripped you off?</TD></TR></TABLE>
honda
honda
Solbros Owns Me
Re: (jay.dee.em1)
DON"T GET A HARNESS JUST YET!!!! lol...
I had the exact same problem....pull the plug off of the bulb and inspect it. Guaranteed it is either burnt or the femal ends are pulling apart.
Just clean the contact surfaces and press them closer together....see if that works
Moderator
Re: (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">DON"T GET A HARNESS JUST YET!!!! lol...
Just clean the contact surfaces and press them closer together....see if that works</TD></TR></TABLE>
great info!!
great info!!
Re: (chad)
maybe you guys have seen this before im not sure, but there is this nasty *** ****** gunk all over the contacts for the plug, its kinda brown. maybe i should jus get another connector at the junkyard, jus get the harness and see if i can splice the new piece in there?
Solbros Owns Me
Re: (lswift)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lswift »</TD></TR><TR><TD CLASS="quote">maybe you guys have seen this before im not sure, but there is this nasty *** ****** gunk all over the contacts for the plug, its kinda brown. maybe i should jus get another connector at the junkyard, jus get the harness and see if i can splice the new piece in there?</TD></TR></TABLE>
you could do that too....
see, for me....my pass low beam would every once in awhile go out...and for about 3 months, I would have to turn my headlights on, pop the hood, and wiggle the plug and the light would come on- until I cleaned the contacts. In my case, the previous owner had LOST the rubber seal to protect the back of the bulb and the plug from the elements....
and the "gunk" you are talking about, is most likely the protective lube from the factory, that they use on engine bay connections....especially on fuse box and un used relays
but do what CHad said first and check the fuse. ALWAYS CHECK FUSES FIRST!
Re: (eddiecut)
what fuse is the 1 for the low beams? i dont exactly have a fuse panel in my ek.. ****** **** fell out... where was that electrical tape when i needed it ****! lol
off this topic, i was poppin the hood and my ******* DAMN &^%*& hood release lever/pull **** broke the **** off now i gotta use pliers... just use some liquid nails on that bitch or replace it... and from where. thanks.
slowcoupe93
07-03-2007 05:05 PM
