EK egine won't start after alarm removal
New User
Please help!!!
I bought the civic EK 2000 dx, and I try to convert to power window. I bought the floor harness from EK SI 2000 and have replaced it completely. After that I found an old alarm system in the car, but which is not working; therefore, I remove all the brain,sensor,relay, and harness. I also took the fuse box out, after that I plugged everything back in. Now everything work fine; signal, headlight,and other etc, but the engine. I try to start, it sound like normal like it would start, but no. it crank, but the engine won't run. I gave up and don't know what wrong with it. Thank you!
Re: EK egine won't start after alarm removal
when you turn the key on (right before start), does the fuel pump prime? if not it's either a fuse or the main relay.
Tony Starks
09-20-2003 07:34 AM
