ej1 with mini me swap -- How wire vtec?
Eyy what's good, jus recently purchased my first ej1 with mini me swap. Needs vtec wired? How do I go about doing so? Or should I just take it somewhere? If so what is usually the cost? At input helpful. Will post pics as I progress
Re: ej1 with mini me swap -- How wire vtec?
Thread titles MUST summarize the tech problem (be topic specific) so that members browsing titles can understand the problem without reading the post. Title edited.
took me literally 2 minutes to find this on a thread.. use the search engine
You’ll need to run the blue wire (or whichever color is from the plug) to pin D6, and then run the black ground wire from the plug to anywhere on the motor. You then need to run the green wire from the VTEC solenoid to pin A4.
badassgixxer
09-03-2008 11:07 AM
