Eg turn signal problems
I have a 92 civic cx...and my left turn signal flashes quickly, while the right turn signal flashes fine. Along with the quick flashing, the left front indicator light flashes dimer than all the other lights, when i press the hazzard lights, all flash the same speed, except front left indicator light...i have already replaced bulb, socket, combination switch.....can anyone give me some diagnostic advice?
Re: Eg turn signal problems
What voltage to body ground do you measure for the hot wire at the bulb receptacle?
What resistance to body ground do you measure for the ground wire at the bulb receptacle?
The resistance of the ground is a little high, but not terrible. You could try cleaning the G301 ground connection for that ground wire.
The voltage measurements are important. What's the problem there?
The mm is to slow, it says ol, then when switch clicks on...it begins to read, then before it gives me a reading it switches to OL before it gives me a reading
same thing happened to me. there's a little white box with wires coming from it in the engine bay over by the corner light. I tightened the bolt that holds the white box up and it fixed my problem. I assume thats like a ground or something but thats all it took to fix mine.
I Read a wiring diagram, and the front and rear turn signals are split internally in the fuse box, then after fuse box, its a straight shot to bulb...so maybe a bad fuse box? Or wiring....?
