EG Sloppy steering, unresponsive why ? ...
Old 06-30-2003, 11:56 PM
LSHatchback's Avatar
Default EG Sloppy steering, unresponsive why ? ...
Hey guys I have a 92 hatch, just curious about the steering kinda, i can turn it about 6 inches both ways and barely have any response at all < - NO P/S ... any ideas on how to easily fix this ? also I have to turn the steering wheel so much just to make a corner, smaller wheels and stuff do make a little difference or the turning amount but not on the sloppy looseness ... if any has any idea please post !!
Old 07-01-2003, 07:10 AM
jaxle's Avatar
Check for leaks etc. get a Haynes manual if u dont have one and check out the steering gear etc.
Old 07-01-2003, 07:15 AM
powerofdreams8's Avatar
Default Re: (jaxle)
check the tie rods/look into getting them replaced. If those are not the culprit it may be easiest to buy a new rack from http://www.hondaautomotiveparts.com
Old 07-01-2003, 07:57 AM
Thirty-Nine's Avatar
Default Re: (powerofdreams8)
I've go a similar problem, I think. I have a 98 EX coupe (with PS). My fiancé has a 98 EX sedan. Her steering is a lot tighter than mine and mine is less responsive, too. It almost feels like mine is over assisted. Any thoughts? Possibly the same problem as above?
Old 07-01-2003, 09:35 AM
euclid's Avatar
Default Re: (Sushiboy)
take out your ps system, they are extremely overboosted
Old 07-01-2003, 10:14 AM
Default Re: (euclid)
Why, though, would my fiancé's car not feel overboosted compared to my EX? What would be the difference?
Old 07-01-2003, 05:35 PM
CXHatchback's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euclid &raquo;</TD></TR><TR><TD CLASS="quote">take out your ps system, they are extremely overboosted</TD></TR></TABLE>
He doesn't have P/S.
Check your tie rod ends. When the balljoints on them go, the steering goes to **** and there's a lot of play. I replaced mine and the steering was so much tighter. They're really easy and only like $11 each from the parts bin, OE.
Old 07-01-2003, 06:57 PM
euclid's Avatar
Default Re: (CXHatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CXHatchback &raquo;</TD></TR><TR><TD CLASS="quote">
Check your tie rod ends. When the balljoints on them go, the steering goes to **** and there's a lot of play. I replaced mine and the steering was so much tighter. They're really easy and only like $11 each from the parts bin, OE.</TD></TR></TABLE>
my bad... and yes you are definately right about the tie rods, both mine went and when i replaced them it fel much better, autozone sells them for around 25$ per side w/ a lifetime warantee, and the job is easy enough for you to do in an hour or so.
Old 07-01-2003, 07:07 PM
Eee Pee's Avatar
Alignment also.
A touch of toe out will get that quick off center feel.
Cesar_gsr
03-18-2013 05:49 AM
mattvivsound
05-22-2008 10:33 AM
sca2face
08-23-2006 10:28 PM
finest_GSR
05-31-2006 10:00 PM
LSHatchback
07-07-2003 11:35 AM
Quick Reply: EG Sloppy steering, unresponsive why ? ...
