EG oem sway bar diameter
what's the oem 92-95 eg si diameter? i'm looking at a jdm one which is 20 or 21mm so i wanna know if it's worth it to buy the jdm one
Re: EG oem sway bar diameter (jdmbb6)
Front Sway: 22mm
Rear Sway: I don't think they came with one, but if they did, it's probably 13mm or 14mm (I think..)
BTW, if you go with a thicker rear sway bar, it's recommended that you reinforce your subframe to prevent tearing it.
