EG`s > those of you with GSR dash swaps, using GSR dash harness ->
If you`re using GSR dash harness in your EG and turn signals not working, PM me, I may have a fix where everything is working 100%.
I`m trying to see if this fix works for every dash swap before I write up a full how-to.
Re: EG`s > those of you with GSR dash swaps, using GSR dash harness -> (Pho Realtor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pho Realtor »</TD></TR><TR><TD CLASS="quote">Poison Pho Real yO!</TD></TR></TABLE>
j00 know it pho real
Re: EG`s > those of you with GSR dash swaps, using GSR dash harness -> (poison)
all you need to do is give the yellow/black or yellow (i forget since ive done it) wire on the hazard switch 12volts..
Re: EG`s > those of you with GSR dash swaps, using GSR dash harness -> (Hybrid95CivicEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid95CivicEX »</TD></TR><TR><TD CLASS="quote">all you need to do is give the yellow/black or yellow (i forget since ive done it) wire on the hazard switch 12volts.. </TD></TR></TABLE>
Ya, correct. Did you do this? I did this with mine, and my turn signals are now working, but the right turn signal is blinking rice-a-roni style.
I just wasn`t sure if it was the relay in the fuse box that is fugged up, or the wiring...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">
I just wasn`t sure if it was the relay in the fuse box that is fugged up, or the wiring...</TD></TR></TABLE>
yes i did this a long time ago. i recently have done the swap to a friends car and used the civic harness and rewired the guage cluster wires.. there are differnt ways of doing it.. its probably blinking fast cause you have a bulb burnt out on the right side either signal or parking light.. check those and see if im correct..
yes i did this a long time ago. i recently have done the swap to a friends car and used the civic harness and rewired the guage cluster wires.. there are differnt ways of doing it.. its probably blinking fast cause you have a bulb burnt out on the right side either signal or parking light.. check those and see if im correct..</TD></TR></TABLE>
That`s the first thing I checked. Still blinks quick =X
I`ll have to switch bulbs from the left to the right and see if it`s just a ghetto bulb in the socket.
Re: (H22AEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22AEG »</TD></TR><TR><TD CLASS="quote">same wit mines dash swap.. how the heck do u guys sit it all the way in.. is it direct fit? mines looks ghetto</TD></TR></TABLE>
no its not a direct fit.. how far off is yours?? it will not line up w/ the doors and also on the side of the dash.. it looks good, but not perfect!!
Re: (H22AEG)
are you having the same problem with your turn signals?
Re: (H22AEG)
quiet adam!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22AEG »</TD></TR><TR><TD CLASS="quote">yeah.. but i got it fixed already i fixed it... the same way.. tap into the hazzards but the dash doesnt sit properly</TD></TR></TABLE>
yep my dash is working 100% now. no more rice-a-roni
what mounts did you use for your dash?
Do not purchase anything from me. -HT Staff
i was using stock civic dash mounts... but i took it out to see if it would sit more in.. it did but now that **** moves around and **** lol
Re: (H22AEG)
I would use the Integra dash mounts. Mine currently is sitting just fine, my gauge cluster will not go all the way in, however due to the steering column support. I'm going to work on it to make it fit properly, and try and remove the caps by the door trim, and solder the connections.
I will take pictures of the Integra mounts when I remove the dash again..
Re: (H22AEG)
HENRY ....remember how Sangs brother has it sitting...it was PERFECT...the only things that was ghetto looking was the inner side of the doors...sooo no it will FIT directly if you know how to do it.
Re: (poison)
i dont have any mounts on right now... took it off so it sits more in.. but it wobbles.. i have stock civic ones tho
HybridKOOP
01-02-2007 09:37 AM
liketofry
Honda Civic (2006 - 2015)
10-13-2006 08:08 AM
HybridHatchC1
04-20-2004 03:43 PM
