ecu/tuning
Old 05-11-2006, 08:07 PM
mugen si's Avatar
Default ecu/tuning
i have a 2000 civic si with the b16a2 in it. this car comes with the obd1 ecu right?? Also i would like to kno if getting the car tuned will help in power(how much $ to do so)??? i have cams(stage 1 head job), aem cold air intake, jdm headers and catback apex'i n1 exhaust, along with a chipped ecu. i was also wondering if all memory in the ecu after being tuned, would be lost if the battery is disconnected.
Old 05-11-2006, 08:34 PM
ekb16's Avatar
actually ur car is obd2b..tuning ur car will cost somewhat alot bcuzz they gotta put it on a dyno and tune everything..usually a dyno tuning will cost somewhere between $50-100 an hour (just a guess never dynotuned my car b4 but i noe it costs alot) and no the memory wont be erased if u disconnect the battery
Old 05-11-2006, 09:02 PM
cambopheonix56's Avatar
Default Re: ecu/tuning (mugen si)
Your car should be obd1, because someone put an obd1 ecu in it if its chipped. Yes tuning your car will give you a few ponies.
Old 05-11-2006, 10:42 PM
tegman85's Avatar
if its obd2 you would have to convert it to obd1 and you could just get a good street tune for around 150 to 200 or go to dyno and get a tune which will be better than a street tune for around 100 an hour and would probably only take about 1 1/2 hours since your n/a
Old 05-12-2006, 09:15 AM
mugen si's Avatar
alright. thanx for the help. i bought the car from the previous owner with all this already done. he said that he had it dyno tuned b4 the cams and chip added. so i would like to retune it to compensate for them. i am pretty sure its the stock ecu(havnt actually looked at the ecu yet), he only mentioned to me that he had a spoon chip put in.
Modified by mugen si at 12:27 PM 5/12/2006
Old 05-12-2006, 09:33 AM
mugen si's Avatar
i had the understanding that u could only chip the obd1. so if my car comes stock w/ the obd2 it must have been converted right? if i pull the ecu out how can i tell if its chipped? thanx.
Old 05-12-2006, 09:40 AM
cute little bastard
SkoundrelUSA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugen si &raquo;</TD></TR><TR><TD CLASS="quote">i have a 2000 civic si with the b16a2 in it. this car comes with the obd1 ecu right?? Also i would like to kno if getting the car tuned will help in power(how much $ to do so)??? i have cams(stage 1 head job), aem cold air intake, jdm headers and catback apex'i n1 exhaust, along with a chipped ecu. i was also wondering if all memory in the ecu after being tuned, would be lost if the battery is disconnected.</TD></TR></TABLE>
The car from factory comes with a OBDIIb ECU, but apparently you're running a OBD1 ECU so I guess theres a conversion harness there.
Getting the car tuned will help a lot. It will most likely cost 400-600 then 100 every hour depending on the tuner.
That spoon chip is probably garbage.
Old 05-12-2006, 10:15 AM
EH339's Avatar
Default Re: (mugen si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugen si &raquo;</TD></TR><TR><TD CLASS="quote">i had the understanding that u could only chip the obd1. so if my car comes stock w/ the obd2 it must have been converted right? if i pull the ecu out how can i tell if its chipped? thanx.</TD></TR></TABLE>
Open the ecu and look inside of it. If it's chipped, the ecu will also be socketed.
I think the best combo is first a street tune for setting the partial throttle values, then on to a dyno for the full throttle adjustments. And dyno time is more expensive. I suppose it depends on who your tuner is and how thorough a job he wants to do.
Old 05-12-2006, 02:19 PM
tegman85's Avatar
you can tune fuel for part and full thottle but timing needs to be done on the dyno
handafreak2112
Engine Management and Tuning
04-05-2013 11:34 AM
itr1244
06-09-2009 11:17 AM
spotscivic
07-08-2007 04:53 PM
adidasklip
05-03-2006 08:51 AM
SiR-DC2
02-19-2003 09:44 PM
Quick Reply: ecu/tuning
