ECU problem.. please help !!
Hey guys... My 98 honda civic was running kinda rough, so i just brought it into the dealership yesterday. I forget the exact terminology, but basically they said my ECU was fried and i need a new one. they want $1000 to get a new one and install it. This is pretty freaking expensive, is this too expensive? what should i do? thanks for all your help
Re: ECU problem.. please help !! (Admiral Assjack)
this is way too expensive...an ecu is plug and play. Search in the classified forum and look for a used P2P that is the ecu you need. (assuming you have a stock setup)
Modified by Built2Spill at 8:13 AM 4/14/2004
Re: ECU problem.. please help !! (Ki3t)
i just have the stock 98 honda civic dx engine... 1.8 liter? nothing fancy.. thanks for all your help.. i appreciate this. is this an easy do it yourself install ? thanks again
Ya man no way should you ever spend 1g on an ecu... Go hunt the classified section and look for the ecu you need.
Install is just plug and play, meaning you unclip the wires out of your old ecu and just plug them right up to your new ecu.
Is it stick?
and btw you got a 1.6L
If it's auto I got a p28 of a 94 laying my buddies trunk, sell it for cheap
Oh yeah you should of told that guy at the dealership to **** off
damn 1000! Talk about the stealership. You should be able to get another ecu for $100 Just search on here.
Re: ECU problem.. please help !! (ABK)
its a stick. boy.. thsi is such a releif to hear that i can get one for like under 200. Do ECU's ussually go out? should i be concerned with getting a used one? i just need the basic stock ecu.. the exact model thats in my civic.
no concerns...ecu's are normally reliable unless they are treated incorrectly. Just search around in the classifieds for a P2P, and when you get it take out your old ecu and plug in the new one...easy as that. let me know if you need help on identifiying the placement of the ecu.
Re: ECU problem.. please help !! (Built2Spill)
Heres waht i dont get. The CEL came on and it was running pretty rough, so i took it to autozone and got their free diagnostic check. and there machine said i needed a new "Air Charge Sensor".. so then i take it to the stealership.. and they say i need a new ECU? they didnt mention anything about the air sensor.. should i check out the air sensor first.. or do you think this is an ECU problem. is and air sensor hard to install? this sucks... i thought my honda would never have any probs.. its only got 80k on it.. oh well.. let me know your thoughts
i think you might be talking about the mass airflow sensor on the intake....if you are throwing a code then your ecu shouldnt be the problem. I would recommend now that you purchase a new mass airflow sensor and install that...it too is easy to install it is located by the throttle body. then if your car is still not running properly, which it should be then i would recommend an ecu.
hmmm...learn how to check your ecu codes. Just do a search...theres a ton of posts on it. When you check it if you just get a flat code where the light just stays on and doesn't blink you a code then that means your ecu is messed up. Otherwise it may be something else.
look on the passanger side on the right hand side kick panel for a connector (2 wire - blue in colour) behind plastic cover which needs to be removed exposing the ecu. find it, short out the connector using a paper clip/wire and turn the key over to on position and count the number of blinks. long blink = 10, short = 1.
thanks to katman more visual goodies:
codes and the meaning:
Code Meaning
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
check PDF file for tracing to the sensors
http://hyperducktuning.com/hondatechhelp
as far as finding ECU check the board first, then if fails check the following lists all the parts avalible in your state and outside :
http://car-part.com/
Code Meaning
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
Re: ECU problem.. please help !! (eg6ajk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk »</TD></TR><TR><TD CLASS="quote">look on the passanger side on the right hand side kick panel for a connector (2 wire - blue in colour) behind plastic cover which needs to be removed exposing the ecu. find it, short out the connector using a paper clip/wire and turn the key over to on position and count the number of blinks. long blink = 10, short = 1.
Code Meaning
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
http://car-part.com/</TD></TR></TABLE>
awesome info!!!
Code Meaning
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
awesome info!!!
heel_touge
Engine Management and Tuning
05-14-2009 09:48 AM
