ECU pins = wtf.
ECU pins = wtf.
so i'm doin my swap and it's time to switch A17 to A20 and i'm taking an A/C pin to use for the knock sensor, but how the **** do you get the pins how? i used a needle nose and released the little clip things on the top/bottom of the ECU clip, and i tried using a tiny screw driver and put it in and wiggled both the wire and the screwdriver and pulled just a little bit and nothing happened? i tried the paper clip and that didn't work? is there some special way to do it or something? wtf....
Re: ECU pins = wtf. (j0nptw)
ok ****** seriously this **** is gay..... is there a certain way to push in the small tip that your using and wiggle it free or what? cause this is frustrating... all i need is 2 of them to come out that's it....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j0nptw »</TD></TR><TR><TD CLASS="quote">ok got it.... thanks anyways</TD></TR></TABLE>
You are very welcome
Re: ECU pins = wtf. (Turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer »</TD></TR><TR><TD CLASS="quote">
You are very welcome </TD></TR></TABLE>
GetawayInMoscow
07-25-2005 01:09 PM
