ecm problem??
ecm problem??
so i just pulled the cel code on my new motor an i got p01607. which is P1607 Engine Control Module (ECM)/Powertrain Control Module (PCM) Internal Circuit Malfunction..... im not sure what this means. does anyone else no what i should do to fix this???
its a 99 civic si
jdm block
wiseco 9:1 pistons
eagle crank
eagle rods
arp bearings
skunk 2 stage 2 turbo cams
skunk 2 pro series valve springs and retainers
ferria valves
its a 99 civic si
jdm block
wiseco 9:1 pistons
eagle crank
eagle rods
arp bearings
ferria valves
Re: ecm problem??
If you hope to get useful replies, then provide all relevant information about your car and engine:
https://honda-tech.com/forums/showpo...48&postcount=2
Please familiarize yourself with the stickies at the top.
--->Have you tried resetting the ECU?
Re: ecm problem??
the motors a jdm block wiseco 9:1 pistons, eagle crank eagle rods arp bearings the heads got ferria valves skunk 2 stage 2 turbo cams and valve springs. sorry im new to the sight. but noe im gonna reset the ecu in a few minutes.
