drum brakes vs me round 3
try to install drum brake cover and it will not fit.
so i kicked the car and the jack fell and the lower control arm is all bent. <J/k>
not funny but i wish i could of kick the damn car.
so how can i get that cover to fit i have the manual and did everything it said and still nothing?????
help me out asap so i can get some sleep...
i tried to search but it said it was down... so i hope some one is one line tonight.
Re: drum brakes vs me round 3 (92 CIVIC HATCH VX)
lol, your post made me laugh. Good thing you didn't actually kick your car.
Anyways, bump for you i guess.
are the brake pads stopping it?? if so you are gonna have to get a c clamp and press then in
all drum brakes I've worked on you have to adjust them in as the new pads have a lot more meat on then, hope this helps. Funny story though, thanks for the good laugh.
Re: drum brakes vs me round 3 (Kista20)
Yep, move the self-adjuster gear enough until you see the shoes retracting. The drum should slip right on after this... but now you want to take it off again and move the shoes back up so they are making slight contact. You should have some resistance when you try to turn the drum when it's on, but not so much that you can't turn it with one hand...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 CIVIC HATCH VX »</TD></TR><TR><TD CLASS="quote">yes it's up
You need to have the E brake off when putting the drum on. Then loosen the self adjust nut enough to get the drum on.
And jackstands are $10 at autozone.
Re: drum brakes vs me round 3 (EX_AutoXer)
I hate drums thats why you get rear disks like me. My wheel cylinder on my drums gave out next to mac truck and I couldn't slow down to save my butt. thankfully it was late and not much traffic so I got off the road with out a scratch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Is the E brake up? </TD></TR></TABLE>
lol.... i nailed that one Aight this is what you do. Get a piece of 2x4 on the front ties and put it in gear (if its a manual) Then drop the E brake. When the E brake is down it should go right on.
Re: (_OEM_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _OEM_ »</TD></TR><TR><TD CLASS="quote">you didn't happen to step on the brake pedal with the drum cover off did you?</TD></TR></TABLE>
im sure if he did hed have brake fluid squirting 20 feet out the side of the car
Re: (drunknbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drunknbass »</TD></TR><TR><TD CLASS="quote">
im sure if he did hed have brake fluid squirting 20 feet out the side of the car </TD></TR></TABLE>
Depends how hard the pedal was stepped on... might just blow the wheel cylinders. I'm ashamed to admit to it, but I learned the hard way.
#1 Super Guy
Re: (CycloneBlue_1.6EL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CycloneBlue_1.6EL »</TD></TR><TR><TD CLASS="quote">
Depends how hard the pedal was stepped on... might just blow the wheel cylinders. I'm ashamed to admit to it, but I learned the hard way. </TD></TR></TABLE>
Don't be ashamed, the lessons that you learn (the hard way) can really help people out in big ways...
same here which is why i asked haha. luckily, it wasn't that HARD and and the cylinder's decompressed after 48 hours.
Re: (_OEM_)
Pull the rubber boots back on the wheel cylinders on both sides, make sure there is no brake fluid in there. If there is, you might as well replace them now before they damage anything else. If they are leaking, even slowly, and some of the brake fluid goes on any of your brand new friction material, you'll be replacing it all again. Just a heads up to do it right the first time, save yourself some money and headaches in the near future.
Fucken auto parts store gave me the wrong shoes....................
them bastards.
ok i was wondering my these were alittle too big.
so i took the other side off to check and it was off alot.
ok so figured out they gave me the wrong parts.
then i install the old one's and started bleeding the brakes with the other side drum off.
the cylinder popped off and fulid leaked everywhere ok so. i decide to started to please the side that popped off and then i go for the bleeder valve and broke it off>>> mother **** the bitch snapped in half.
so i thin i have to take the whole assembely off ? and drill the vavle out i guess??? or sell the car????
them bastards.
Re: (92 CIVIC HATCH VX)
drums arnt fun.. i remeber the first time i did a brake job on a honda drum.
i fucked the wheel cyl up and had to replace it and got pissed and took the whole drum assembly off.. but once i looked it it long enough and i understood how all the springs and **** worked. it ws worth learning, cause ill never **** one up again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 CIVIC HATCH VX »</TD></TR><TR><TD CLASS="quote">you know how much the wheel cylinder cost?</TD></TR></TABLE>
They're cheap, less than $20. You can get a rebuild kit at Napa for less than $5. I rebuilt mine, it's only one or two O-rings and the rubber boots.
