Door open(beep) noise.
Old 09-06-2008, 09:47 PM
wh1zd0m's Avatar
Default Door open(beep) noise.
Whats up yall I have a quick ? and some help would be appreciated.
My car just all of a sudden stopped making the noise when the door is open and key in the ignition.
The questions kinda obvious so im asking what needs to be re-placed/fixed.
Thanks in advance.
Old 09-06-2008, 10:04 PM
THC07's Avatar
Default Re: Door open(beep) noise. (wh1zd0m)
wow, sounds like you were givin a gift, why fix it? i hate that beep
Old 09-06-2008, 10:06 PM
turbojdmhatch's Avatar
Default Re: Door open(beep) noise. (THC07)
theres a sensor on the door jam that when the door is open it makes the beeping noise...fix it? i say no i hate it...if u have other friends with hondas and they leave teir keys in their car run and open all their doors its kindafunny to hear all of them beeping
Old 09-06-2008, 10:17 PM
wh1zd0m's Avatar
Default Re: Door open(beep) noise. (turbojdmhatch)
Yeah i hate that ish too, but its busted or broken, so im tryin to fix it.
So with the sensor does it have to be re-placed?
Any cause to why it could not be working?
Old 09-06-2008, 10:20 PM
theres usually a rubber coating over the sensor u could get a new one from a junk yard or honda dealer
Old 09-06-2008, 10:27 PM
H-T White Ops
NOFX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wh1zd0m &raquo;</TD></TR><TR><TD CLASS="quote">Whats up yall I have a quick ? and some help would be appreciated.
Thanks in advance.</TD></TR></TABLE>
It's actually called the ignition key reminder (aka "key-in reminder") btw.
Old 09-06-2008, 10:28 PM
Default Re: Door open(beep) noise. (NOFX)
yea i was gonna ask if aomeone could post up a diagram for him
Old 09-06-2008, 10:46 PM
wh1zd0m's Avatar
Cool thanks for the info NOFX. I knew that it had to be a sensor of some type, but i didnt know what it was nor what it was called.
Old 09-06-2008, 11:38 PM
I am my avatar
naRIPSTA's Avatar
I love the beep lol, I some times DO forget that I leave the keys in the car. No matter how annoying it is, it's saved me a few times.
Old 09-06-2008, 11:39 PM
obuhmyuh's Avatar
theres a fuse, on the driver side by your right knee as well.
Old 09-07-2008, 02:14 PM
gizzerhatch's Avatar
mine only goes off sometimes it depends on the key. i have to wiggle the key a bit for it to make the sound
Old 09-07-2008, 02:29 PM
Seagull Management
94EG8's Avatar
Default Re: Door open(beep) noise. (gizzerhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gizzerhatch &raquo;</TD></TR><TR><TD CLASS="quote">mine only goes off sometimes it depends on the key. i have to wiggle the key a bit for it to make the sound </TD></TR></TABLE>
Mine did that until I finally got a new key cut when i was living away from home and figured out that I could barely unlock my doors with the original key, I'd never really bothered to lock my doors before that.
Old 09-07-2008, 03:56 PM
tazeat's Avatar
So where is the beep device, I want to remove mine. i HATE that beep. I still want the sensor though as its part of the alarm...
Old 09-07-2008, 06:41 PM
H-T White Ops
NOFX's Avatar
Default Re: (tazeat)
Manual doesn't mention where it is. Might have to trace. I have no idea where it is.
Old 09-07-2008, 06:45 PM
Eg2Love's Avatar
sometimes mine beeps, sometimes it doesnt.... totally random. i think its the most annoying sound in the world but i wouldnt feel right disabling it... its like a classic honda trademark... the "Honda Beep"
Old 09-07-2008, 07:05 PM
Seagull Management
94EG8's Avatar
From what my diagram tells me (not very much) its in the underdash fuse box in some sort of a combination relay that also seems to control some usefull stuff. I think I may just remove the little switch on the ignition switch on mine, i do not now, nor will i ever have an alarm so it really doesn't matter much.
Old 09-07-2008, 07:29 PM
BoSox46GSr's Avatar
Default Re: (94EG8)
It's on the back of the door jam on the drivers side. Notice, when it's going off, close your door slowly, wait for it to stop when it hits that rubber piece. I believe it's a philips head to take it off.
Old 09-07-2008, 07:41 PM
TheJGB3's Avatar
Does your dome light come on when you open the door?
Old 09-07-2008, 07:57 PM
Seagull Management
94EG8's Avatar
Default Re: (BoSox46GSr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoSox46GSr &raquo;</TD></TR><TR><TD CLASS="quote">It's on the back of the door jam on the drivers side. Notice, when it's going off, close your door slowly, wait for it to stop when it hits that rubber piece. I believe it's a philips head to take it off. </TD></TR></TABLE>
Thats the door switch for the dome light, what this guy wants is the actual beeper unit itself, and if was gonna get rid of anything other than that it would be the actual switch on the ignition switch that knows the key is there. I like my dome light controlled by the door switch.
Old 09-07-2008, 08:01 PM
H-T White Ops
Frozen E's Avatar
Default Re: (TheJGB3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheJGB3 &raquo;</TD></TR><TR><TD CLASS="quote">Does your dome light come on when you open the door?</TD></TR></TABLE>
x2
If it doesn't then that switch in the door is bad. Not a huge PITA but remember that 9 times out of 10 this switch is used for the alarm. If that switch never closes then a thief could actually open up the door with the alarm armed and it'd never go off.
Old 09-07-2008, 09:00 PM
SoCal EJ1's Avatar
Default Re: (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">
x2
If it doesn't then that switch in the door is bad. Not a huge PITA but remember that 9 times out of 10 this switch is used for the alarm. If that switch never closes then a thief could actually open up the door with the alarm armed and it'd never go off.</TD></TR></TABLE>
That's why you buy air-pressure sensors for the interior auxiliary part of the alarm. I have some, they work great.
Old 09-07-2008, 09:21 PM
H-T White Ops
Frozen E's Avatar
Default Re: (SoCal EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
That's why you buy air-pressure sensors for the interior auxiliary part of the alarm. I have some, they work great. </TD></TR></TABLE>
Interesting. Never heard of those.
Old 09-07-2008, 09:23 PM
tazeat's Avatar
I'd still want the switch to work for the dome light and stuff where is the damn beeper
Old 09-07-2008, 09:27 PM
SoCal EJ1's Avatar
Interesting. Never heard of those.</TD></TR></TABLE>
new technology. if a door opens or window breaks, the alarm is triggered by the chance in pressure. only downside is I can't park with my windows cracked on a hot day because any decent breeze will trigger it.
Old 09-07-2008, 10:18 PM
i love my honda beep
Quick Reply: Door open(beep) noise.
