Door inserts
Door inserts
So i have done my door inserts in suade but i am not satisfied with the result i have been thinking for months now how to fix it and ive seen people dremel out their door panel insert but later on how do they re attach it back on??
#1 Super Guy
Re: Door inserts
If your talking about an EG, you have to use a dremel to cut off heads of the melted plastic rivets. Once you make it flush with the plastic panel, the two pieces should pop apart. Some rivets are easier than others. The trick is not to dremel too deep. That way you can put the parts back together with short taping screws and washers where the melted-rivets used to be (there are small holes in the center of each rivet).
BTW: While your at it, you should add some EX door pockets if your stock panels have the bolt provisions on the back side: http://www.norcalcivic.org/forum/viewtopic.php?p=16118
Re: Door inserts
Re: Door inserts
I'll make a future video when my car comes time for interior restoration.
JDM_SOHC
39
08-03-2014 04:04 AM
