00 Em1 requires starting fluid to start but runs fine after.
Old 02-27-2013, 03:22 AM
BuiltDC2's Avatar
Icon3 00 Em1 requires starting fluid to start but runs fine after.
So I've searched quite a few forums but cannot find my situation. Here's the Scoop
00em1 all stock.
Car ran perfectly fine getting ready to start a huge Turbo build on it.
Relocated battery to the trunk. Ran a 2gauge wire from battery to.under dash. Used a splitter to run 1 wire to fuse box and another to the starter.
Car is getting fuel to the rail.
Its getting spark.
But will only start with starting fluid
When it starts with starter fluid it runs fine I drive it around the block like it never had an issue. I come home turn it off And it will not start back up. Once again I spray the fluid starts fine runs fine.
Any ideas would be greatly appreciated. Thank you
BuiltDC2 is offline
Old 02-27-2013, 03:27 AM
rd91sib18c5r's Avatar
Default Re: 00 Em1 requires starting fluid to start but runs fine after.
When was the last tune up? Could be the fuel filter. Have you tried giving it a little
gas while trying to start it?
rd91sib18c5r is offline
Old 02-27-2013, 03:39 AM
BuiltDC2's Avatar
Fuel filter is new. Actually all the lines leading to the rail have been replaced with-8 lines with an earls inline. And yes I do give it some throttle while trying to start.
BuiltDC2 is offline
Old 02-28-2013, 03:12 AM
BuiltDC2's Avatar
Figured it out! Main positive wire for the battery was defective. Thank you rd91sib18c5r for your input!
BuiltDC2 is offline
Old 02-28-2013, 03:30 AM
Cool glad you got it.
HondaJDMLife
08-24-2014 11:35 AM
dustyhd5
06-06-2009 02:04 PM
DaMmniTz
02-11-2005 02:16 AM
Accord15
06-25-2003 09:54 AM
Quick Reply: 00 Em1 requires starting fluid to start but runs fine after.
