does this look right? WITH PICS
hey guys, i finally installed my cai on my 1999 civic dx, i had to cut parts of the splash guard off and you can see the filter now on the bottom, i am curious if this is what it is supposed to look like( maybe urs isnt exactly the same but i wanna know if i did it right ) oh and when i was my car should i avoid getting it wet? here are some pics, tell me what u think.
Re: does this look right? WITH PICS
i didnt just take off the splash guards, i cut them out, so i cant really "put" them back in... and i dont drive it in the rain, but idk that doesnt seem right to me, how it is so close to the ground, is there anything i can drill behind it so i can cover it up and so it looks better? maybe another piece of plastic or something? any ideas?
is there a thing they make to install in a brake in the pipe to prevent this. hydro lokcing it looks like a circle filter.
found it here look http://cgi.ebay.com/ebaymotors/AEM-B...=p4506.c0.m245
wow... are u serious, ur asking for a really dirty air filter. the splash guard is there for a reason. This is asking for a hydrolock also, if you live in a rainy place.
hey guys, all i wanna know is, what is the best way to pull the filter up so it doesnt sit so low, the only way i can think of is, to pull the 2nd part of the pipe an inch or two higher and hold it there with something but idk what to use? any ideas? i will try to put some black plastic around the filter so it doesnt get dirty and so its not loose.
Hydrolock waiting to happen!
And can you cut a small section out of the piping, so that it pulls the filter up higher? I don't know how many pieces it is, just trying to help man.
Colonel Cake Mix
Colonel Cake Mix
aem does make one and if i were the OP i would purchase an aem one cause there is something to be said for the R&D into there products
i purposely cut the splash guards because my filter wouldnt fit... dont u think that if i bring the filter up an inch higher that it should be fine, its not really dusty where i live nor does it ever rain lol, so i dont think that splash guards would be my choice here, i think that i should find a metal piece and bring the filter up a little higher, thats all, if u have any other ideas except splash guards, hit me up
Colonel Cake Mix
bring the filter up for sure, but i would still get that bypass valve for the simple fact that if u submerge your filter in a puddle for whatever reason (we all make mistakes) you will be SOL. Its your choice man, but the 40-50 bills is cheaper than a new motor
it never rains here... so i dont need a bypass, my problem is that the filter sits very low which isnt normal, i just want it to sit higher, but idk if it is necessary to put anything around it, i dont know if it will get that dirty?
Colonel Cake Mix
i understand it doesnt rain man, my whole thing is better safe than sorry, as far the dirt, just raise it and throw a splash guard on (u will want this anyways). you can get a filter cleaning kit too if u are that worried. Just keep an eye on it for a little to make sure. Good Luck
i had mine exactly like that for a while. i have never had a problem with hydrolocking or anything.
as for raising it up, there should be a few holes in the metal right above that behind the headlight. you could always run some zip ties through there and raise it to your desired level
thats a good idea, ill try to do some stuff like that, i will raise it up, but do u think that i should cover it up or something or is it fine, it wont get too dirty will it? brutekiller787, since u had to same problem, did urs ever get that dirty?
yeah thats kinda scary bro... lol just go with SRI or mod the piping to raise it up a bit... because if you run into a puddle of water... then ur gonna be
despite what everyone is saying, unless you are rallying the car and get in a puddle that is fully covering the filter you will not hydrolock the engine. the engine can't pull enough vacuum to lift that much water into the engine.
but i don't drive in very dirty places, but still, except for some small rocks that get caught between individual fins, the filter doesn't get all that dirty. you do have to clean it more often though. i clean mine every 6 months
