Does the EM1 Si wing mount with the same holes as the EX spoiler?
Picked one up for the wife and decided I might mount it earlier and paint it to match. Wondering about the holes in the trunk though. I'm wondering if anyone happens to know by chance? Would save me some body work on the trunk and having to match paint, which I don't want to do right now.
Thanks
Thanks
Re: Does the EM1 Si wing mount with the same holes as the EX spoiler?
NO THEY DONT!!!!
the si has a higher spoiler 5 inches taller then the ex also the electrical for the cyclops light is on the oposite side for the si model allthough the mounting bolts (4 ten mm bolts) are the same
I should've clarified further. She has a 97ex wing (lower profile), and I bought her an EM1 si wing. Should be good to go though.
H-T White Ops
Yes, they do.
Incorrect.
You're thinking of the '96-'98 coupe spoiler versus the '99-'00 coupe spoiler.
The '96-'98 coupe spoiler is lower and has a long LED light bar.
The '99-'00 coupe spoiler is higher and has "CIVIC" embossed on the bottom next to the LED light bar. The light bar on '99-'00 coupe spoilers is not as wide as the '96-'98 one.
'96-'98 sedans and '99-'00 sedans also have different styles of spoilers too. The '96-'98 sedan spoiler is lower than the other trunk lid spoilers and has three legs on the bottom. The '99-'00 sedan spoiler has two legs and looks very similar to the '96-'98 coupe spoiler, but it pointier overall.
The sedan spoilers are less common than the coupe spoilers.
I'll just take it off and compare them side by side for the answer. It appears they are the same, but as is typical with the model specific forums there is constant conflicting information.
I have been through the same thing.
Yes... the 99-00 Si spoiler will mount into the same holes as the 96-98 spoiler.
ok cool i knew there where diffrences i am mistakin. good info, i dinnit kno it was 96-98.
H-T White Ops
1996 1997 1998 1999 2000 96 97 98 99 00 wing spoiler tall short fit holes bolts bolt up match up same trunk
Glad I could help clear things up a little bit.
I spy some search tags....too bad the search sucks anymore...lol. It seems to be improving kind of...but nothing like the old one.
Sounds like a go though...good deal.
onelane
16
08-02-2006 09:16 AM
