Does anybody know what the specs on this piston means?
Re: (JDMlifestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle »</TD></TR><TR><TD CLASS="quote">
9:1 is the compression ratio. which means how much volume it takes up inside the cylinder</TD></TR></TABLE>
Correction, it means it'll compress every 9 o2 and gas molecules into the space that one takes up at 1bar.
Re: (allmighty2door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmighty2door »</TD></TR><TR><TD CLASS="quote">so i have to bore the cylinder wall to be 75 mm? or 75mm more? </TD></TR></TABLE>
what motor are you going to install these pistons in? if the pistons are 75 mm, then you would have to bore your existing cylinders to 75mm.
try using the search function. For example, type in "d16z6 bore"
https://honda-tech.com/zerothread?id=496636
WOW!!
WOW!!
Dave_Dc2
11-03-2008 10:48 AM
