Does 94+ integra cluster direct fit for EK?? PLUG AND PLAY???
Old 02-28-2005, 01:54 PM
SOKDO's Avatar
Default Does 94+ integra cluster direct fit for EK?? PLUG AND PLAY???
i saw an ek on HT with gsr cluster. is this plug and play? if not... what needs to be changed or modified???
Old 02-28-2005, 02:31 PM
b20vtecEK's Avatar
Default Re: Does 94+ integra cluster direct fit for EK?? PLUG AND PLAY??? (sokdo321)
no, you have to re pin part of the harness
Old 02-28-2005, 06:04 PM
BlueIntegraBoy's Avatar
Default Re: Does 94+ integra cluster direct fit for EK?? PLUG AND PLAY??? (b20vtecEK)
You need to repin the plugs. https://honda-tech.com/zerothread?id=1053318
Result...
I've done this swap 2.5 times. The .5 came when I swapped a 96 GSR cluster from an EK and put in a 98 spec JDM ITR cluster. I had to move two wires.
Old 01-18-2022, 09:48 AM
raphaelgonzales's Avatar
How you did with the cluster frame to fit in the EK dashboard ?
Old 01-18-2022, 10:52 AM
stin1's Avatar
From the stolen photobucket pic not well .
striker5661
13
02-03-2010 06:57 PM
D Griff
11-26-2009 07:19 PM
bballzplaya
07-25-2008 09:24 PM
needforvtec
10-09-2006 07:57 PM
alispoon
11-10-2005 03:24 PM
Quick Reply: Does 94+ integra cluster direct fit for EK?? PLUG AND PLAY???
