Do these pistons look damaged? Help out a noob
Old 08-18-2014, 03:20 AM
DOHCoftheBay's Avatar
Default Do these pistons look damaged? Help out a noob
Noob here. While helping a buddy clean out his garage, low and behold we found these pistons. He rented the house out for years and some of the tenants left behind some goodies apparently.
We would like to know if they look damaged because they look relatively new to us. Of course visual inspection is not gonna tell us everything, but its a start.
Old 08-18-2014, 03:54 AM
stillsingle's Avatar
Default Re: Do these pistons look damaged? Help out a noob
They look good but I don't think there's any rings on them. If there for a d16 that's probably why they left them.
Old 08-18-2014, 04:23 AM
H2EJ's Avatar
thats an interesting find. they do look pretty new... lol i concur rings would be important.
Old 08-18-2014, 05:15 AM
JDM_SOHC's Avatar
You must have skipped over that picture of the piston with the wrist pin that got sledge hammered in lmao..
I don't think that the engine displacement had anything to do with why they were left behind, a bottom built D16 can put down some pretty impressive numbers..
Old 08-18-2014, 06:56 AM
Fish Twig
tony_2018's Avatar
yeah, that one must've had it roughed.
Old 08-18-2014, 07:28 AM
Norlael's Avatar
I would have those big ends honed too before you use them, that rust can throw off your bearing tolerances.
Old 08-18-2014, 08:58 AM
too bad i don't have an EK anymore. o well. finders keepers still. I'm gonna see if there are any d16 dreamers in the marketplace forum.
after finding some acura chain tensioners, i'm guessing he and his wallet went K-series and never looked back
Old 08-18-2014, 11:39 AM
boosted-93hatch's Avatar
Pistons look good and almost new except for the one with some gashes around the pin.
I would not be afraid to use them.
Old 08-18-2014, 10:48 PM
Retired Moderator
EsotericImage's Avatar
The gouged one looks fine to me..
The part of the pidton that doesnt look fine are the tops..
They arent supposed to be shiny. Get sandpaper and a scotch brite pad and rough up the tops and smooth over any sharp edges. This includes the corners.
Those rods are Probe which also make Scat's line.
Old 08-19-2014, 08:47 AM
ekhatch1227's Avatar
How much are you looking to get of the set
Old 08-19-2014, 03:42 PM
After reading up a bit about pistons and rods I took a closer look. Here are closeups of the one nicked piston. I also noticed a few tiny nicks on the top of the same piston but I have no idea if this damage is negligible or significant ... anyone care to enlighten? All the rest of them look pretty clean.
and the top of the same piston.
Old 08-19-2014, 07:11 PM
Retired Moderator
I already gave you the answer on post #9
Old 08-19-2014, 08:26 PM
Stancetard Hate Monger
eghatch9295's Avatar
nope, theyre garbage. ill give you $20 for the set
tinkerbell
18
04-11-2010 07:32 PM
sirt_eg
04-08-2009 09:31 AM
all motor b20b
01-30-2005 04:01 PM
MotorMatrix.com
07-15-2003 10:22 AM
Quick Reply: Do these pistons look damaged? Help out a noob
