DO I NEED THIS ON MY B16 HEAD??
do i need these to run my motor?
only reason im asking is because i took my valve cover off today and all of them were off, laying by the valvesprings.
some were bent as you can see but im more worried about the one i cant find.
i only found 15 of these, i took them out since they are damaged and no sence i put them back on cuz there gonna fall off again.
can anyone tell me why they would come off in the first place?
and where the last 1 could have went?
and DO I NEED THESE TO RUN MY CAR?
let me know asap.
thanks guys,
rob
Re: (mike93boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93boost »</TD></TR><TR><TD CLASS="quote">holy ****.</TD></TR></TABLE>
my thoughts exactly
my thoughts exactly
Re: (mike93boost)
How did those just come out/?? That is crazy....
To answer your question, Yes you do need those.
Those are your valve seals. With out those you leak oil where the valve stems go through the head. Buy your self a helms manual and get to work bro.... or trust a head shop with it...
Re: DO I NEED THIS ON MY B16 HEAD?? (underb00steg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underb00steg6 »</TD></TR><TR><TD CLASS="quote">o man .....just to let you know ...those are called valve seals ......</TD></TR></TABLE>
No, they aren't. I wish people could quit spreading this crap around. They are valve STEM seals. Ok? They seal the valve stem to the guide, they do not seal the valve itself. People get these all mixed up when you use the wrong terms.
He has a mix of intake and exhaust there. Exhaust are black, intakes are white. You can see the color of the rings.
Anyways, yes, you need those. Without them, you will be using oil like mad.
Re: (mike93boost)
what he said
what he said
Re: (4sd4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4sd4dr »</TD></TR><TR><TD CLASS="quote">yea, there was no need for all the ******* sarcasm, the guy asked a simple question.
they are called valve seals on honda and acuras part sites.
furthermore, I was under the impression that the exhuast valve stem seals had the springs on the top...</TD></TR></TABLE>
I wasn't trying to be sarcastic. I was trying to clear things up. People ask me questions saying they heard about the "valve seals" on Honda-tech cause this and that. They don't understand that its a STEM seal and simply regulates oil supply to the guide. It doesn't seal the valve itself. I was just trying to help clarify this. Should have known many a person would get butthurt.
Re: (Tuesday Club)
there should be some very small markings on top of each one, right by the spring. I think the exhaust VALVE STEM SEALS have an E on them, forgot what the other ones have. Maybe an I for intake
Re: DO I NEED THIS ON MY B16 HEAD?? (=ITRpoweredEK9=)
damn that sucks, i guess my car is down...
i dont know how they all came off, i mean when we did the valve adjustments i put everyone one snug, whats gonna keep the next set from coming off?
anyone know where the last one could have went.... oil pan maybe?
expletive i dunno already, this never happened to me so sorry if i sound like a noob.
damn i really needed my car to get to work. does it damage anything if i drive em without the valve stem seals on?
and what can i do to prevent them from coming off again?
thanks for your help guys and no need to get crazy with each other this is my stupid problem...
thanks again.
rob
thanks again.
rob
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underb00steg6 »</TD></TR><TR><TD CLASS="quote">o man ...i hope he's just playing..just to let you know ...those are called valve seals ......and you do need those</TD></TR></TABLE>
Re: (mike93boost)
i second that...
i second that...
1 Post
Someone didn't put that head together correctly. They should go on under the valve springs.
For example:
See the one with the spring off? see the seal? That's where they go on any motor.
For example:
cute little bastard
I have some never used ITR valve STEM seals. I'll let them go for cheap since I have no use for them
