DIY - How to put on 92-95 eg civic ferio rear door panels
For those EG JDM ferio guys out there...
I bought my ferio door panels off ebay a couple of days ago and it came today. I put them on my car and made this installation guide to help future ferio fans out there.
Tools required:
-flat screwdriver
-philip screwdriver
The package:
Mine came used and have 2 screws on each panel and does not include the inner panel.
Pulling it out:
1. Working from the inside of my left rear door. It took me a while to find a way to pull it out, but I managed to do it correctly. It is much more simple than you think. Simply pull down where indicated by the red arrow (emphasis on down). Pull hard, but slowly to avoid breaking anything (use a flat screwdriver if you need to loosen some sides). The top metal clip holder indicated by the green circle should disable in time. The other two bottom latch should just slide out with ease.
Here's a picture of how the holders should line up:
2. Once taken out, use your philip screwdriver and unscrew the 2 screws holding the outer panel. There's only 2 screws, so you can't miss it.
The disassembled panels:
3. Replace your stock panels with the ferio panels and do the steps backwards. You're done with one side! Repeat it with the other side. That's all.
Finished work:
I hope this helps...if there's anything I'm missing, please note me.
Any comments/suggestions welcome!
Tools required:
-flat screwdriver
-philip screwdriver
The package:
Pulling it out:
Finished work:
Re: DIY - How to put on 92-95 eg civic ferio rear door panels (handa)
how much you buy dem bitches for? and on a good DIY...not may posts for ferio/sedan owners around here
Re: DIY - How to put on 92-95 eg civic ferio rear door panels (slowdx9585)
i had those on my four door, until i turned to the hatch side of civics, makes me miss that blue car...
Re: DIY - How to put on 92-95 eg civic ferio rear door panels (diearzte2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diearzte2 »</TD></TR><TR><TD CLASS="quote">Excuse the n00bness of the question... but what exactly is a ferio? </TD></TR></TABLE>
JDM 4 door 4WD civic.
Re: DIY - How to put on 92-95 eg civic ferio rear door panels (NateTL17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NateTL17 »</TD></TR><TR><TD CLASS="quote">
JDM 4 door 4WD civic.</TD></TR></TABLE>
Not always 4wd. Not usually actually. From what I
have seen thats more of a Euro thing.
Re: DIY - How to put on 92-95 eg civic ferio rear door panels (elwood)
The 4wd civics eg sedans are pretty damn rare really.
Their matchstick-like rear driveshafts don't look too sturdy either.
