DIY: Fixing Doorlocks that open with any key...
#51
Premium Member
Re: DIY: Fixing Doorlocks that open with any key...
Another update: I bought a beat up 94 Civic RTSi in New Zealand in June 2015. The key that came with it only operated the driver's door which had been replaced at some point in the car's history (it still had the original passenger's side door, and trunk), and while it did operate the ignition, this is only because the ignition cylinder was so worn that any Honda key could operate it. These JDM cars do not have a locking trunk mechanism by the fuel/trunk lever, nor one to unlatch the rear seats.
Getting a fresh key cut for it at a NZ Honda dealer was not a financially viable option (>NZD$70, for whatever reason), and still left me with the ignition problem, and I then would have a driver's door issue instead of a passenger's door + trunk issue. Instead, I resolved to use this DIY to replace ALL the lock tabs on the doors + ignition to match the key on my 93 Civic Si that I had back in Canada. At the junkyard I actually found a Honda that my key worked on. I pulled that and noted the lock tabs order. I then pulled a few more lock tabs from other vehicles and eventually I had enough to replicate the lock tab order of my 93 Si on all the locks of the 94 RTSi. I swapped these all in and all was once again right in the world, with the added convenience of only requiring one key for both vehicles.
#52
Premium Member
Looking forward to rebuilding the Rock Auto cylinder with my original lock plates so I can keep using my key. Hope the lock plates fit!
Getting that little spring back on kind of sucks!
klerbman
02-02-2019 07:45 AM
roaddawg
04-08-2018 07:30 AM
rlansdon
06-02-2008 10:06 AM
