DIY Digital Tach
DIY Digital Tach
I'm currently working on a digital tach project primarily for EG Civics but it should work with all OBD1 Hondas. The project details can be found here: http://hackaday.io/project/2614-Honda-Digital-Tach
There are links to the code repository and I'll be updating as I make progress. The goal is to get the whole thing down to a single PCB and inside a 1 or 2 piece 3d printable case. The project will be open source so anyone will be able to download, make and modify the design to their own needs.
Let me know what you guys think and if there are any features I should look into adding. Thanks!
Re: DIY Digital Tach
Yea that shouldn't be an issue. I'd have to get the waveform from the sender and adjust the code and the filter but there's no reason why the same approach couldn't be used.
Oh look, I can change this
Have you seen this thread? All sorts of words in there that I don't understand but I know enough that it gives me tingles.
