diy coilover ek
diy coilover ek
so im looking to build my own setup. i found a place that sells just the coilover springs. i was gonna grab a set of ebay collars and some koni's with extended top hats. wats everyone think?
i was thinking of ksport or apexi springs. its a daily, so im going for comfort
Re: diy coilover ek
Why not just get Koni/ground control?
Koni shocks are different then stocks. They have a "cir clip' that the sleeve grabs. The Sleeves NEEDS to be koni spec. No names are not.
Ek Forever y0!
Re: diy coilover ek
If you want a comfortable daily just get ground controls with the off-the-shelf rates. I can guarantee you ebay or ksport springs are not going to be comfortable.
For some reason a lot of people think springs are comfortable and coilovers are not. Neither is more or less comfortable than the other. It all depends on the spring rate.
Re: diy coilover ek
Don't buy ebay coils, its like they built em and never tested them out because those things break like nothing. Ground Controls, Function & Form, and Eibach are really good.
Re: diy coilover ek
Or, they think a 350lb spring is back breaking stiff.
I can't find the thread anymore but there was a guy that had ebay coilovers and the spring rates ended up being 650lb for all 4!
Ek Forever y0!
Re: diy coilover ek
Its becuase they buy low quality parts that typically have very high spring rates and put them on cheap shocks.
Re: diy coilover ek
grab urself ef fork take them to a machine shop get then make the diameter big enough for ur ek struts to fit inside. automatic 2 inch drop without making ur car drive like **** on ebay coils.
Re: diy coilover ek
Yes, my 350lb rears deffinetly make it a little harsh, and not as comfy as I would like sometimes, however they deffinetly are not that stiff.
I6turbo
Suspension & Brakes
21
02-25-2005 12:27 PM
