Distributor Question for a 2000 Civic Ex w/ swap?
I have been making a few phone calls and reading up on some stuff, and apparently my 2000 civic ex coupe's distributor is one of a kind, all 2000 ex's are different than any other car and only work with each other. I have a B-Series swap in the car right now, but the only thing i need to get it running is a different distributor b/c the B series plug won't connect with mine, 1 too many wires. Do you all suggest replacing the entire engine harness, hot-wiring it so they connect but just have 1 usless wire, or what? What B series distributor would match up with my car? ANY SUGGESTIONS ARE HELPFUL THANKS
Re: Distributor Question for a 2000 Civic Ex w/ swap? (RDix)
I know there are plenty of you all with 2000 Ex's with B-Series swaps..whats your setup, i really just don't want to have to cut anything...let me know what you all think please.
you need a 99-00 Si engine harness , for some reason honda changed the plugs on the obd2b dizzy's and wiring ... there was just another thread on this
Re: Distributor Question for a 2000 Civic Ex w/ swap? (ReDHaTcHyGuy)
The guy who had the motor before me, had it in his '98 ex coupe and everything hooked up fine...but you think a 99-00 Si Engine Harness will plug up with an 01 B18c5?
they changed they style of the dizzy plugs after 98.. thats why your haveing trouble.. yea the Si harness will work fine. if you wanna use the hondata u have to get a obd2b-obd1 conversion harness..
W95civicEXcoupe
02-18-2015 02:33 PM
slo_ej8
04-09-2008 09:01 PM
