difference between valve clearance and valve adjustment???
can anyone plz tell me what is what. people tell me that its the same thing, but i dont think so. valve clearance is the clearance between the camshaft and rockers. but i was wondering how you adjust the valves? can anyone help???
Re: difference between valve clearance and valve adjustment???
when you do a valve lash ADJUSTMENT you check and correct(if needed) the valve CLEARANCE between the camshaft and rocker. you use a feeler gauge to check the clearance of each one.
adjust, adjustment, civic, clearance, crx, difference, honda, hondatech, lash, replacement, valve, valves
