Dies when i get gas?
hopefully you guys can help
when i put gas in and start up the car..the car will start then die or sometimes not start at all
i have to try to start it more than once everytime i put even 1 gallon of gas in..this starting happening about the beginning of this month..what could be the problem?
*LS motor into Civic*
question two..kinda off topic..but will an 00 SI exhaust fit a LS header? are they the same length or if i buy one from a site do i get a civic one or integra one?
thanks!
thanks!
Re: Dies when i get gas? (krazyhmongboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazyhmongboi »</TD></TR><TR><TD CLASS="quote">hopefully you guys can help
thanks! </TD></TR></TABLE>
Try to do a diagnostic troubleshoot. What's cutting out, fuel? electrical power? Honda has some problem electrical paths, like the main relay or the ignition switch. Post the findings of your tests.
i'll probably try a test...its the fuel cause it only happens when i put gas in..every other time i start it after that..it works fine =/
Re: (krazyhmongboi)
I had this problem with my 92 eg6 not too long ago. I could drive the car for days but after I would get gas it would take forever to start... It turns out that I needed to change my main relay, I'm still not 100% sure why but it definately solved the problem.
LvN
19
06-08-2006 06:58 AM
LvN
06-06-2006 12:21 PM
